585,727 active members*
4,241 visitors online*
IndustryArena Forum > MetalWorking Machines > Bending- and Punching Machines > Press brake newbie - Need help... Going to buy a press brake for the first time.
    Jun 2021
    We have a small prototype shop and we want to have our own press brake and not always have to rely on external sources.
    We are located in Vietnam so it is fairly convenient for us to buy direct from China and get it over here by truck. We have looked at a few machines online and to be honest we have no clue what to look for.
    We want an NC 2-axis machine (do one need more axis for simple jobs?). We mostly need to bend small sheets but we plan to make some large stainless (1mm) workbenches, 2300mm long, later so we thought we might go for a 2500mm machine.
    The small items we have are 3mm 5052-36 aluminum not longer than 1200mm, but mostly only 100-300mm wide. We have got really good prices, so low so we are getting concerned about the quality.
    So this is the reason why i'm posting here. I'm a press brake beginner so i hope for some advice here: What should we pay attention to? What are the parts that they may cheap out on? The controller is an Estun E21 and the X-axis has a single servomotor with timing belt (looks cheap), and they are asking around $6000 EXW for a 40t2500mm...
    All suggestions and directions are highly appreciated. Thanks
    Jun 2022
    8
    Re: Press brake newbie - Need help... Going to buy a press brake for the first time.
    I suppose this is not very actual but maybe somebody found it.
    1. Simple machine more than 1500 will be Y1, Y2 + X. It means 3 axis. Maybe asians make Y1+Y2 as one.
    2. For this price you should pay attention that the machine is work, tool system allows to purchase tools locally and you are comfort with the control.
    Sure it is one servo for backgauge.
  1. Converting Conventional Hydraulic Press Brake to CNC Press Brake with PC
    By aadityadengle in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2023, 05:23 PM
  2. Press brake strategies: Bending the right part at the right time in the right way
    By Gurgen_Aleksanyan in forum Maintenance DIY Discussion
    Last Post: 10-25-2020, 07:18 PM
  3. Press brake tools, bending tooling for press brakes from Italy
    By pressbraketools in forum News Announcements
    Last Post: 05-19-2018, 11:06 PM
  4. Looking to buy Used Press Brake
    By magma-joe in forum Bending, Forging, Extrusion...
    Last Post: 01-16-2012, 09:05 PM
  5. Selecting Press for home shop press brake
    By tikka308 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2009, 05:51 AM
