585,589 active members*
2,927 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Looking for Silent Servo Motors
    Jun 2021
    Question Looking for Silent Servo Motors
    Hi there!
    I am looking for silent servo motors. I know that most hobby servos do a lot of buzzing and humming. But do you know of any hobby or professional normal size servo motors that are actually silent?
    Thank you so much for your help!
    ygreq
    Quote Originally Posted by ygreq View Post
    Hi there!
    ygreq
    Hey, what you are looking for are zero-cogging servos. These range from motors with skewed magnets or stacks to slotless motors. Both are less torque dense. Slotless motors are great for low cogging harmonics which are a typical noise source, but torque ripple is an issue. Pair with a driver that has >24kHz switching frequency and carefully tune the torque loop to eliminate significant ripple.
    You may have a hard time finding these already in housings, Kollmorgen and Celera Motion make frameless kits for $$$. If it's silent for hobby use... let us know if you find it!
    24220
    Re: Looking for Silent Servo Motors
    I use BLDC servo motors with simple A-M-C current mode (transconductance) amplifiers and they are perfectly silent down to 0 rpm.
    It depends on the quality of the feedback.
    When BLDC first came out, a salesman told me they could not be used at low rpm without buzzing.
    That is true if used open loop in a voltage control mode.
    I used a motion card to control the axis where the feedback response is 12mhz .
    Albert E.
    Hi there!
    ygreq
    We use GSK servo motors, so far so good.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Nov 2013
    4347
    I use Delta B2 series servos, Taiwanese brand, made in China, good quality and support at fair prices and very quiet while not actually silent.
    750W B2 (160,000 count per rev encoder) series servo/drive/cables for $438USD plus shipping is pretty fair value.
    Craig
  1. Simple Servo questions- Do all servo motors use differnt drivers?
    By ltortuya in forum Servo Motors / Drives
    Last Post: 11-04-2015, 07:38 PM
  2. servo motors or stepper motors for ATC machine
    By Fanny-Roctech in forum Roctech CNC Routers
    Last Post: 04-21-2015, 03:29 AM
  3. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
  4. Silent servo with gecko 320/340
    By xaq in forum Gecko Drives
    Last Post: 01-31-2007, 03:28 AM
