585,717 active members*
3,874 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > How can I run Nema23 @ 2or3 rpm
    Mar 2017
    7
    I have a spare Nema 23 & M335 driver which I would like to be able to run at very low variable speeds for a non CNC project.
    Is there an easy way to achieve this? Potentiometer maybe? Or am I being naively hopeful.
    Dec 2013
    5717
    Re: How can I run Nema23 @ 2or3 rpm
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2012
    1267
    Here is another one that will work:
    https://www.ebay.com/itm/294216615395
    Problem is, these boards may have too wide of a speed range for you. At the lowest setting, the speed will change from 1.5RPM to 45RPM (80Hz to 2400Hz).
    Mar 2017
    7
    Thanks Jim
  1. Optimal RPM and Leadscrew to run on Nema 23
    By eugkra33 in forum Complaints and Praise Discussions
    Last Post: 03-30-2018, 07:09 PM
  2. advice on voltage and amps to run higher RPM
    By Ncrazyballa in forum Stepper Motors / Drives
    Last Post: 07-21-2012, 12:40 AM
  3. Yaskawa SGDM cannot run over 400 RPM!!
    By danielm in forum Servo Motors / Drives
    Last Post: 04-11-2012, 11:30 PM
  4. Novakon 6000 RPM spindle: Run at 9000 ??
    By Frogblender in forum Novakon
    Last Post: 10-29-2011, 08:54 PM
  5. What RPM to run at?
    By neoga34 in forum Bridgeport / Hardinge Mills
    Last Post: 10-29-2010, 07:03 PM
