585,568 active members*
3,718 visitors online*
    May 2016
    9
    A2100 probe wiring
    Hello,
    Can anyone help with wiring a probe into the a2100 control.
    I am using a MI12 control and mp12 probe.
    I have the wiring diagram and plugs.
    I have everything wired and the MI12 is getting a signal from the OMM when I touch the probe.
    The machine is not receiving the signal.
    What probe port do I use in the setting?
    Am I missing something?
    Aug 2009
    1570
    Re: A2100 probe wiring
    for one thousand Alex? How to
    Mar 2008
    285
    Jesse_H, The probe Port is documented in the Control Diagrams i.e. 9120xxxxy stamped on the serial plate. The Systems Options for Spindle Probing must be enabled as well as the Machine Application parameters properly set.
    May 2016
    9
    I have the wiring diagram for the machine.
    Everything is wired a working on the renishaw side
    The a2100 control is not receiving the status input from the MI 12?
    Does anyone know if the MI12 status output is voltage or ground?
    May 2016
    9
    Hello All,
    I got this figured out, If anyone needs help feel free to contact me.
  1. Active probe cable wiring
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 08-19-2013, 08:08 PM
  2. Probe Wiring with Relay?.
    By mick-uk in forum DIY CNC Router Table Machines
    Last Post: 10-23-2011, 11:29 PM
  3. A2100 and tool probe Arrow
    By brokenrinker in forum Cincinnati CNC
    Last Post: 01-23-2009, 10:37 PM
  4. A2100 probe alignment
    By lfriend86 in forum Cincinnati CNC
    Last Post: 09-17-2008, 03:39 AM
  5. DIY Probe wiring Q?
    By Tazzer in forum Digitizing and Laser Digitizing
    Last Post: 02-20-2006, 02:47 PM
