585,931 active members*
5,616 visitors online*
    Jul 2010
    13
    Unhappy Feed rate problem.
    Open program and load a code with say feed of F250 and press cycle start . Program runs a feed rate of 6mm min or just ticking over. Hit Stop , GOTO Zero ,Rewind code and cycle start and away we go , feed rate is whatever I have set in code . This only happens on initial cycle or each time I load Mach3. Any thoughts Appreciated.
    Nov 2012
    1267
    Re: Feed rate problem.
    Does your program specify units of measurement in the header (G20 or G21)?
    Jul 2010
    13
    Quote Originally Posted by CitizenOfDreams View Post
    THE LINES IN PROGRAM HEADER
    NO1 G21 G40 G49 G54 G80 G90 G91.1
    NO2 G53 Z0
    Nov 2013
    4371
    when Mach3 loads and/or resets it defaults to what is a presumed safe feed rate of 6mm/min.
    If you wish to change that behavior then include a 'F300' or whatever in the pre program Gcode string, you can find and edit it in the Mach3 General settings
    page. I have not used Mach3 for nearly seven years because I adopted Mach4....and my memory fades on those little details.
    Craig
  1. Problem with feed rate not changing
    By jcrouch in forum Mach Mill
    Last Post: 12-26-2017, 03:49 PM
  2. newbie having a bit of a problem with feed rate
    By plnewton in forum BobCad-Cam
    Last Post: 02-09-2015, 12:50 AM
  3. Feed rate problem
    By Rene Nuñez Paz in forum Hobbycnc (Products)
    Last Post: 03-09-2009, 01:50 AM
  4. Feed Rate Overide problem
    By Moondog in forum Machines running Mach Software
    Last Post: 06-14-2006, 11:35 AM
