586,009 active members*
4,865 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Electric Fan Air Cooled Chinese Spindle
Results 1 to 7 of 7
    Jun 2005
    10
    As in the title I am looking for a 4.5 to 6 kw air cooled electric fan Chinese spindle but am having no luck sourcing one. Does anyone know where to purchase these if indeed they are even produced.
    Thanks for any help.
    Mar 2017
    926
    Re: Electric Fan Air Cooled Chinese Spindle
    Electric fans are usually only found in more expensive spindles. Cheap Chinese spindles usually use shaft fans or water cooling. I've only seen electric fans in some of the more expensive ATC variants.
    I have one in my PDS spindle. They have pros and cons. You get better cooling at lower speeds but high speed cnc router spindles usually have limited use below 6000 rpm anyway.
    I.e. You still aren't going to being able to achieve decent performance with large diameter tools or use HSS end mills if that was the goal.
    You also get slightly worse cooling at high speeds (and high speeds generate more heat).
    I have a little regret in my choice. If I was doing it again, I would have gone with a water or compressed air cooled spindle.
    I know you didn't ask all that but I thought I'd share what I wish I would have known myself when I was buying a spindle.
    Jun 2005
    10
    If I do decide to go with a water cooled system, has anyone tried the chillers that are available? I really do not like the idea of a bucket of water and the heat that would be generated by a spindle of this output would be substantial.
    15362
    Quote Originally Posted by dakmon View Post
    Yes a lot have started using the chillers now it is more convenient the water cooled spindles are very efficient, and don't need as much cooling as you are thinking as long as the have flow is the main thing, the liquid needs to be treated with an anticorrosion
    Mactec54
    Jun 2005
    10
    Good to know. I see now that there are a few threads on the subject. Where are most purchasing their units? I am ordering a spindle from China, maybe I should source the chiller there as well.
    Mar 2017
    926
    I like to use ebay for cheap Chinese electronics because they give you some protection against dishonest sellers.
    If you plan to cut metal then spindle cooling is only half of the consideration. You'll want a mist or flood coolant system too.
    Cutting aluminum with high speed spindles generates a lot of heat. I can feel a huge difference in how hot the spindle gets if I don't use adequate coolant.
    Jun 2005
    10
    Not likely to cut any metal, but will scour ebay for a suitable chiller.
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water cooled Chinese Spindle - air leak
    By analogman in forum Spindles / VFD
    Last Post: 06-23-2016, 02:08 PM
  3. Replies: 1
    Last Post: 04-21-2016, 05:38 AM
  4. Replies: 0
    Last Post: 02-12-2016, 10:54 PM
  5. chinese spindle strip dowm 1.5Kw air cooled
    By Mick Gannon in forum Uncategorised MetalWorking Machines
    Last Post: 10-09-2014, 11:11 AM
