585,992 active members*
5,238 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > okuma svp problems AGAIN
    Sep 2015
    12
    OK, once again I am trying to diagnose svp boards. okuma cadet mate osp700 mill. the alarm is 2010-11 B SVP APA CHECK MAxis E93DE93E
    I believe the error is from the z axis and tool changer. the mill has 2 svp boards. Does one board "communicate" with only the z and tool carousel? or do both boards have something to do with all 3 axis plus the carouel?
    Mar 2009
    1982
    Re: okuma svp problems AGAIN
    Check your entire tool change cycle. If there are no hits, if tool comes into the spindle nose centered.
    It happens when machine is not leveled for a long time and level is lost. Sure, can be more reasons of tool change missalignment.
    Sep 2015
    12
    The machine seems to be level. As soon as the tool carousel starts to rotate, during a tool change, it throws up a svp alarm. 2010-11 Alarm B svp check MAaxis E453E452
    Mar 2009
    1982
    are tools distributed equaly in the carousel?
    Can you move the empty carousel outside the tool change cycle?
    Sep 2015
    12
    tools carousel is empty and like i said as soon as it begins to turn, the alarm pops up. Even in manual mode.
  1. Replies: 4
    Last Post: 07-17-2021, 01:40 AM
  2. OKUMA SVP board: 1-1 CPU Alarm bus error
    By robodo in forum Okuma
    Last Post: 11-13-2017, 10:32 AM
  3. 903 Alarm-P SVP ERROR 3888400 Okuma Help!
    By koch.Cnc in forum Okuma
    Last Post: 03-03-2016, 12:26 AM
  4. Okuma MX-60HB SVP Speed Command alarm
    By Chinook0 in forum Okuma
    Last Post: 02-04-2015, 09:09 PM
