585,967 active members*
4,454 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 31I RS-232 Alarm "CANNOT USE I/O DEVICE"
Results 1 to 2 of 2
    Apr 2016
    I have a Toyoda horizontal machining center with a Fanuc 31I controller. I'm attempting to get the serial port setup so that I can send programs to the machine over RS-232.
    The company that we bought the machine from had this working using the same cable and port.
    I've made changes to the below parameters to match the computer but still get an alarm saying "CANNOT USE I/O DEVICE".
    Parameter 20 (I/O Channel) = 0
    Parameter 21(out channel F.G.) = 0
    Parameter 22(input channel B.G.) = 0
    Parameter 23(out channel B.G.) = 0
    Parameter 24= 0
    Parameter 100=00001010
    Parameter 101= 10000001
    Parameter 102(Input/Output Device) = 0
    Parameter 103(Baud Rate) = 11
    Parameter 110(Separate Control of I/O Channel) = 1
    Any suggestions for what else to look into would be greatly appreciated!
    Thanks,
    Aug 2009
    1573
    Re: Fanuc 31I RS-232 Alarm "CANNOT USE I/O DEVICE"
    ...check Parameter 101 for ASCII code output. Bit 4 should be 1
    see page 321
    http://servicetex.ru/wp-content/uplo...0%B8%D1%8E.pdf
    hope it helps ya
  1. Fanuc 6MB11 "2013 magazine servo unit alarm".
    By Leblondmakino in forum Fanuc
    Last Post: 03-11-2020, 03:36 PM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. Replies: 4
    Last Post: 02-23-2017, 11:26 PM
  4. Replies: 2
    Last Post: 06-14-2013, 12:50 AM
  5. Replies: 0
    Last Post: 11-25-2011, 12:32 AM
