585,930 active members*
3,534 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow Siemens "alarm 40-33 output/fuse failure on APC rack 0"
    I have Arrow with Siemens Control. In the rack, I have DV5 servo board and Profibus DP Card. RT board is G7VP2. I lost bios settings after replace BIOS battery. When I set two interrupts IRQ7 and IRQ15 to ISA in the RT BIOS menu, the machine is undergoing diagnostics. All tests is passed but I have error "alarm 40-33 output/fuse failure on APC rack 0". Has anyone solved this problem? Does anyone have Flash and BIOS settings for RT G7VP2?
    Mar 2008
    285
    Re: Arrow Siemens "alarm 40-33 output/fuse failure on APC rack 0"
    Serwis we reflash these using a binary program and floppy disk; then test the board in a simulator with a special I/O Board tester. The pn on the inside lip of the RTCPU board chassis is 3-424-xxxxAyy. This is what someone would need to know to perform the settings.
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. please help : output file from Enroute have "plt" extension and not "cnc"
    By isam ali in forum Uncategorised CAM Discussion
    Last Post: 06-29-2017, 03:15 PM
  3. Doosan Puma TT1800SY - APC "Alarm" on start up
    By Saranac in forum Daewoo/Doosan
    Last Post: 06-28-2015, 03:07 AM
  4. Replies: 6
    Last Post: 01-02-2014, 08:13 AM
  5. Replies: 2
    Last Post: 06-19-2013, 05:40 PM
