585,715 active members*
3,867 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > A signal or power booster to stepper motor, is ther one do they exisist?
    May 2012
    6
    Unhappy A signal or power booster to stepper motor, is ther one do they exisist?
    I own an old Legacy Ornamental Mill and just recently purchased a used Handibot.
    I have rigged it so I can send the X-axis signal out of the handibot and I used heavy gauge wire but it is around 7' long. So the motor does not engage, not even a little bit, no holding power.
    I am wondering if there is such a thing as an inline power booster for stepper motors?
    Do to the nature of this retrofit I may very well need to add a larger stepper motor anyway.
    Any suggestions or insight would be most kind and thanks in advance for your time,
    -Tim
    Dec 2013
    5717
    Re: A signal or power booster to stepper motor, is ther one do they exisist?
    7' of wire should work with no problems. Maybe a picture or two of what you did would be helpful.
    When you say you are sending the ''signal'' out. What exactly does that mean? You would need to disconnect the motor wires from the HandiBot and run them out to the remote motor. And also have the pairs correctly connected to the remote motor.
    Jim Dawson
    Sandy, Oregon, USA
    May 2012
    6
    Hi Jim,
    I used a set of D9 pin connectors, the Handibot actually had a spot for one to be mounted I assume for a 4th axis. I plugged the original X stepper motor into it and it works great up to that point. So that is where I made the connection it is an A A/ and B B/ rather then a step and direction signal if that makes sense. I hijacked it on route to the original stepper motor so it can quickly go back to a portable CNC unit again.
    I will add photos tomorrow and do some additional testing as I have other working stepper motors on my mini mill and mini lathe I can swap in.
    Thanks for the snappy response,
    Tim
  1. CNC stepper (?) motors have power & signal but won't move
    By nealscnc in forum SERVICE FOR CNC-MACHINES
    Last Post: 10-28-2020, 06:35 AM
  2. Can DRV8825 Stepper motor drive power a 425ozInch/3Nm stepper?
    By DHamilton in forum Vertical Mill, Lathe Project Log
    Last Post: 11-26-2015, 05:17 AM
  3. Power, Stepper, and Signal Cable Lengths
    By amishx64 in forum CNC Machine Related Electronics
    Last Post: 11-14-2011, 09:43 PM
  4. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  5. Need a signal booster to make 3.5v logic 5v
    By Smertrios in forum CNC Machine Related Electronics
    Last Post: 02-02-2007, 01:13 AM
