585,978 active members*
4,564 visitors online*
Results 1 to 12 of 12
    Unhappy spindle speed RPM OFF but VFD work
    I have problem with my specification :
    - win xp sp3
    - vfd huanyang
    - 5axis circuit board mach3
    - mach3 44.66
    - pararell port conection
    - vfd setting using mactec54 i found this forum. wih pd001 & pd002 value 1
    in few days all working well, but change my harddrive and reinstall the winxp and mach3.
    load my last xml setting and now all axis work perfectly except my spindle wont work, when i push spindle cw f5 the F0000 on vfd increacing, RPM on mach3 keep 0 and spindle goes off
    any solution ?
    Re: spindle speed RPM OFF but VFD work
    update i change pd001 = 0 and run, pd0011 from 120 to 0 and hit run..
    now mach3 can start stop spindle, and if i set to 5000 speed, the spindle running well but when increase or decrese the speed its always hit max speed.
    any suggestion ?
    Jan 2018
    1516
    Quote Originally Posted by doraemon_idn View Post
    any suggestion ?
    I had a problem on a new install.
    Spindle would run at full speed on startup and stop when set to full speed.
    Turned out that when I probed the axis board output it was at 10v when stopped and 0v when full (backwards).
    Changing active low / high reversed this to work properly. (0v stopped, 10v full).
    If it worked before then it would be something stupid like this.
    Why change the vfd settings when it was the PC that was changed?.
    The XML won't hold every setting that was user changed.
    15362
    any suggestion ?
    If PD011 was set at 120 then you can not set it at ( 0 ) you will damage your spindle, a setting of 120 = 7200 RPM a setting of 100 =6000 RPM the minimum Speed for a water cooled spindle
    You first have to have the PWM to Analog 0-10v output working correctly at the Breakout Board, before you connect it to the VFD Drive
    Mactec54
    I change because pd001=1 cant start stop spindle, so i turn to 0 and hit run so spindle working well with the button, my spindle 2,2kw air cooling spindle, when pd011 set to 100 or 120 wont turnoff and steady at 6600 rpm so i must hit stop button on the vfd to completely stop.
    Please advice for better option, thanks
    15362
    Wiring is correct
    You have an Air cooed spindle then it will have to be set higher than a water cooed spindle
    You first have to get the 0-10v working correctly before you connect it to the VFD Drive, you need to measure the voltage at the Breakout Board In MDI in your control do M3S12000 the Voltage should measure around 5v do different speed settings and check the voltage
    Your air cooled spindle has a minimum speed it can be run at or it will over heat so even 130 may still be to low for your spindle
    PD011=130
    PD073=130
    PD001=0 ( 0 ) for KeyPad ( 1 ) for Remote )
    PD02=0 ( 1 ) for Remote Control
    J1 Jumper Pin 1-2 for Remote Control
    You may have other Parameters set incorrect if your spindle speeds don't match what they should be
    What other Parameters have you set, post what you have set
    Mactec54
    Wiring is correct
    PD011=130
    PD073=130
    Huanyang Mactec54
    PD000=0
    PD001=0
    PD002=0
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=120
    PD009=15
    PD010=8
    PD011=120
    PD13= 0
    PD014 = 10
    PD015 =10
    PD023=0
    PD026=0
    PD141=120
    PD142=8.5 (matches rating on spindle case)
    PD143=2
    PD144=3000
    PD041=8
    PD70=0
    PD72=400
    PD73=120
    iam using this parameter, but now i change pd001=1 pd002=1 pd011=130 pd073=130 and now the spindle doesnt work
    15362
    The output from the Breakout Board is not working these Parameters PD001 and PD002 setting is for remote control
    Did you set the J1 Jumper Beside the VFD Drive Terminal Block this has to be in the correct position for Remote Control to work
    Is this the voltage of your spindle and the supply voltage what Kw is your spindle motor
    PD08=120v
    PD141=120v
    Mactec54
    Jan 2018
    1516
    Ah. Is that the board you're using below?.
    In terms of M3/M4 control I find the relay a bit useless. If you have BOTH M3 & M4 set up to it in Mach as one on and one off it gets confused.
    You want M3 going to the relay and M4 going to an output that don't exist, or a second seperate relay.
    Then it should switch on/off sort of correctly.
    15362
    Quote Originally Posted by dazp1976 View Post
    Again you don't know what you are even looking at, This is correctly wired to turn the Spindle On and Off there is only one connection the Relay is fine these spindles can only run in one direction
    Stop wasting peoples time with your Bs posts
    Mactec54
    Thanks you mactec54 for your help,
    The trouble is on huangyang vfd, i reset factory again and input all parameter you have again its working perfectly. Now i try to calibrate spindle speed with mach3 coz in vfd says 7500 and the mach 8000
    Once again thanks for your attention and your dedication
    15362
    Yes a Reset can sometimes fix these problems, if a Parameter is set incorrect, it only takes ( 1 ) to mess with the system
    You can use the pulley ratio in Mach3 to adjust the speed to match, do a 12000 RPM and measure the Board output voltage, these Boards there converter is not perfect and most only reach around 9v to 9.8v
    Mactec54
  1. New VFD and spindle motor, RPM too low
    By phootsman in forum Phase Converters
    Last Post: 04-08-2018, 12:52 AM
  2. Hitiachi VFD NE-S1 - Spindle running at low rpm
    By gritandgrainco in forum Spindles / VFD
    Last Post: 02-01-2018, 04:09 PM
  3. Replies: 6
    Last Post: 09-03-2016, 12:51 AM
  4. Replies: 0
    Last Post: 06-10-2016, 03:08 AM
  5. 26 RPM drop in spindle speed
    By dougputt in forum Fadal
    Last Post: 11-05-2012, 01:22 AM
