585,712 active members*
3,783 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > 24v Step-Dir signal for servo drive
Results 1 to 6 of 6
    Mar 2014
    1131
    I'm converting my Optimum BF20L mill to CNC and want to use a servo as spindle motor using step direction signals. The problem is my cnc4pc M16D board (with C78 interface) supports 5v step dir logic sinal but the servo drive (ABB e150) wants 24v step dir logic.
    What is the easiest way to convert 5v signal to 24v signal?
    Thanks in advance,
    Suat
    Jan 2018
    1516
    Re: 24v Step-Dir signal for servo drive
    Quote Originally Posted by Azalin View Post
    Thanks in advance,
    Suat
    How far have you got with this EBB system so far?.
    It's easy to convert a digital 5v signal to 24v for a swich using an opto module:
    https://www.aliexpress.com/item/3301...%2315613%23459
    https://www.cnczone.com/forums/attac...d=466388&stc=1
    BUT..............
    These have standard optoisolators fitted. These are only reliable around a 20khz pulse width. Fine for steppers but not convinced on servo's. If the EBB can work with that then, fine.
    Depending on the pulse width needed for the encoder count, it would need high speed optoisolators for this application.
    At this point in time I would either....
    1: Live with being resigned to running it using analog signals.
    2: Dump either the Pokeys boards or the EBB drive and go with something else.
    Could you possibly build a couple of high speed optoisolation units yourself?.
    Mar 2014
    1131
    Quote Originally Posted by dazp1976 View Post
    Hey,
    I ordered 2 of this. But in the mean time Arturo from cnc4pc sent me this (thanks Arturo). I think it is basically the same thing but the drawing is easy enough for me to understand and build.
    Just ordered some TLP785 units as well.
    https://www.cnczone.com/forums/attac...d=466406&stc=1
    Thanks for your help @dazp1976
    Jan 2018
    1516
    Hey,
    The 785 diagram looks good to me.
    I haven't looked at opto speed data but as long as you don't exceed it's limit you should be all good.
    Nov 2012
    1267
    I would try something simple like ULN2003 (an open collector driver).
    Mar 2014
    1131
    OK I made the unit and I see the input changes when CW/CCW however the servo wont spin when I run simple g-code like M3 S100. I think I'm missing some parameters in the drive.
    That E150 is a beautiful drive but darn there is no info about it.
  1. Step/dir Servo Drive selection
    By WesM in forum Servo Motors / Drives
    Last Post: 12-02-2020, 08:50 AM
  2. Replies: 0
    Last Post: 08-15-2020, 12:02 AM
  3. Servo drive doesn't see step/dir pulses
    By Alekmalek in forum Servo Motors / Drives
    Last Post: 02-15-2018, 03:11 PM
  4. Kflop Step/Dir setup for SGDA-XXAP drive
    By eng101 in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-21-2016, 07:08 PM
  5. 4 line input interface to step/dir drive
    By claya in forum Gecko Drives
    Last Post: 10-24-2012, 04:49 PM
