584,817 active members*
4,582 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > OIL LUBE ALARM LOW PRESSURE
    May 2008
    12
    Hi all,
    We have a VX500 with an Fanuc OI control.
    we overfilled the lube tank and now we have been
    getting a low oil pressure alarm ( even after draining, cleaning and re-filling)
    Need to cycle the pump but I don't know how to do it.
    Currently set at 15 min. Where do I change that? Cant find a relay or button
    to activate the pump.
    Manuals are useless.
    Any help would be appreciated.
    thanks
    Jim
    Re: OIL LUBE ALARM LOW PRESSURE
    If you can post your ladder we can take a look and see which timer is used for the lube cycle
    Apr 2009
    1262
    Your timer T000 should be the lube pause (300000) and the T002 should be the ON time (20000) In your Ladder it should be R726.3 and R726.2 respectively.
    Please verify on your machine since the documentation I have is not for your model.
    Best regards,
    Experience is what you get just after you needed it.
    Jan 2013
    13
    i think below is correct as it was changed later to T02, but difficult to tell without knowing Serial nr.
    timer no.011 timer T020 R726.2 LUBRICATION ON TIME 20000
    also you can try to hold standby switch, which should also turn on the lub pump.
  1. Alarm (low lube,pressure) question
    By BMackinnon in forum Haas Mills
    Last Post: 05-31-2020, 12:53 PM
  2. Leblond / Fanuc OM Lube Pressure No 2050 Oil Pressure Alarm
    By alcarinc in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2015, 03:02 AM
  3. Alarm 121, Low Lube or Low Pressure
    By tjamscad in forum Haas Mills
    Last Post: 11-12-2013, 10:54 PM
  4. Low Lube/Oil Pressure VF2
    By jstucken in forum Haas Mills
    Last Post: 10-28-2010, 02:17 AM
  5. LOW LUBE PRESSURE alarm
    By CORBIN92087 in forum Haas Mills
    Last Post: 08-11-2010, 03:47 PM
