585,676 active members*
4,325 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Impact on speed from extra weight with stepper motors
    Mar 2017
    926
    I recently upgraded one of my axis with heavier mounting plates and it now seems to travel slower.
    With a non-closed loop stepper, would slower travel (after increasing the load) be an indication that it's missing steps?
    Jun 2013
    443
    Re: Impact on speed from extra weight with stepper motors
    Best indication is to setup a set travel path and measure it wouldn't it? I've put a vernier in my vice before, set the machine against it in a positive direction for a couple of mm to make sure it's correct. And then set it to run 100mm (or so) to see what is the actual.
    Speed and increasing it will eventually cause missing steps but speed is not the way to measure accuracy. Also it might be to advantage to download a torque curve for your motor as it drops off with rpm
    Sent from my SM-N970F using Tapatalk
    15362
    Quote Originally Posted by Goemon View Post
    I can't see that you could of added enough weight, for some mounts that would cause it to slow the motors, unless they where on the edge before you did the mod
    At a guess I would say you have something miss-aligned that is causing binding
    Mactec54
    It should not go slower unless you changed the velocity or acceleration settings. For lost steps to cause a lower speed, it would almost certainly be stalling, and not running smoothly at all.
    Mar 2017
    926
    Ok that's helps. It runs runs smoothly and doesn't stall or make excess noise etc. I may have just added extra inertia.
    I have no good way of checking if the speed matches the number I set in linuxcnc. It could be a change in acceleration that I'm seeing.
    Would the same be true for acceleration? I.e. Would I expect it to be stalling or is a drop in acceleration an expected consequence of extra weight with stepper motors?
    And... Should I be worried about acceleration in terms of it affecting accuracy?
    Is this something people fine-tune by adjusting acceleration settings? I left these at default during set-up but there is now a considerable difference in load between my X and Y axis (with it being a fixed gantry / moving table design).
  1. Stepper Motors stutter when jogging full speed at a regular pattern.
    By fatfooey in forum Machines running Mach Software
    Last Post: 09-03-2021, 04:47 AM
  2. Stepper motors not going at full speed....or at any speed.
    By Jack_of_fruits in forum Chinese Machines
    Last Post: 01-10-2017, 09:55 AM
  3. Poor speed on stepper motors..
    By jaru-eri in forum Stepper Motors / Drives
    Last Post: 09-25-2009, 06:07 PM
  4. Impact of gantry weight on inertia of screw driven ?
    By alpouyo in forum Linear and Rotary Motion
    Last Post: 01-08-2009, 08:57 PM
  5. Stepper motors are still going at the incorrect speed. Need help with Mach3
    By Apples in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 12:29 AM
