585,700 active members*
3,525 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma MC-5VA has long pause before starting the spindle
    Jul 2021
    Hi.
    Whenever I try to rotate the spindle, whether through a program or using M3 or M4 in MDI mode it waits, sometimes a couple of minutes before it starts turning. If it's during a program, it will never time out it will just wait however long it takes and then continue once the spindle starts turning.
    One day we just kept messing with it and trying over and over and over again, and finally towards the end of the day it started acting right. However, as soon as it was turned off for a little while the problem came right back.
    Has anyone seen this type of problem before?
    I would be so grateful for any advice.
    Mar 2009
    1982
    Re: Okuma MC-5VA has long pause before starting the spindle
    Check the signal from sin cos sensor. Open cover to see the status of sin cos gear - maybe it is dirty.
    Jul 2021
    Quote Originally Posted by Algirdas View Post
    Thank you for your response! We did open and thoroughly clean the encoder. Do you think that the encoder could be defective, or slipping?
    Mar 2009
    1982
    Hall sensor is involved there. Very sensitive to allignment. Based on magnetic field action - the gap size is important. Re-allign it making gap small as possible. Double ( o multi ) channel osciloscope necessary.
    If sensor is not damaged mechanically, no reason to fail.
    Mar 2009
    1982
    Check tool clamp ( and spindle clamp ) signals stability. These are important to enable the spindle revolution.
  1. Okuma MC-5VA and rs232
    By lenny75000 in forum Okuma
    Last Post: 03-23-2018, 12:58 AM
  2. Okuma MC-5VA ,OSP7000M,subprograms
    By tim shanahan in forum Okuma
    Last Post: 08-19-2015, 08:35 AM
  3. Okuma MC-5VA
    By lenny09 in forum Okuma
    Last Post: 06-05-2015, 02:26 AM
  4. Okuma Howa Millac 5va
    By 69owb in forum Okuma
    Last Post: 07-21-2009, 02:20 PM
  5. Okuma MC-5VA Machine data
    By saschko in forum Okuma
    Last Post: 01-19-2007, 09:21 PM
