585,967 active members*
4,454 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko G320X not responding to Direction signal
    Nov 2003
    452
    Hi, I am controlling the Gecko by an Arduino 256 board.
    The step signal works great and the motor turns according to pulse train.
    Direction signal has no effect and it has been tested on both of the G320X drivers that I have. I was using digitalWrite HIGH and LOW. It always rotates in same direction.
    I plugged the direction signal into both the +5v output of the Arduino and GND and it still had no effect on turning direction.
    I tried changing the COMMON terminal of the Gecko from +5v and GND of Arduino with no effects in both situations.
    I've contacted Gecko and not yet heard back.
    Any suggestions? Thanks
    Shawn
    Nov 2003
    452
    Re: Gecko G320X not responding to Direction signal
    Hi, I found the answer - the Arduino GND and +5v must also be wired to the encoder logic of the Gecko. I thought they were opto-isolated in the Gecko internally (step/dir from encoder) but apparently not.
  1. Troubleshooting Gecko G320x
    By DaStompa in forum Gecko Drives
    Last Post: 08-21-2016, 02:09 AM
  2. Gecko g320x keeps faulting
    By thunderdork in forum Gecko Drives
    Last Post: 08-28-2012, 11:33 PM
  3. Need help with Ports & Pins - motors not responding and/or not changing direction
    By Keveeee in forum Mach Software (ArtSoft software)
    Last Post: 05-02-2012, 03:52 AM
  4. Servo Encoder to G320x Signal Problem
    By pupfield in forum Servo Motors / Drives
    Last Post: 03-09-2010, 02:49 PM
