585,977 active members*
4,054 visitors online*
    Jul 2021
    Question Unknown Alarms
    Hello, I've recently purchased a used Milltronics MB18 with a Centurion 6 controller. Unfortunately it has some alarms and message numbers that I have not been able to resolve. The machine has been sitting for a few years and was disconnected from air as well as low on oil and coolant so thinking maybe those could be some of the messages I'm getting. Also on start up the only way for me to enter CNC mode is for me to reformat the SRAM each time, sometimes it tells me to contact Milltronics and wont let me do anything unless I restart the machine. I've attached pictures of both the start up screens and the main screen with the messages if anybody could help identify some of my problems it would be greatly appreciated.
    Thank you,
    Jeffrey
    Apr 2008
    21
    Search the forum for contact info for Sporty Bob. Good guy and his rates are quite fair.
    Aug 2009
    1573
    Re: Unknown Alarms
    ...this may help if, a dead battery is the cause...those Dallas chips should be outlawed.
    https://www.cnczone.com/forums/millt...r-replace.html
    Aug 2009
    1573
    Re: Unknown Alarms
    ...more information about setting your Paths that may help and also, you need an older type (5Pin DIN plug) AT Keyboard or PS/2>AT adapter to access the BIOS settings.
    https://www.cnczone.com/forums/millt...05059-cnc.html
  1. Seiki-Seicos LII Bubble memory Alarms --- Help on recovering from alarms 104,144,105
    By AZTEXAN_MIMXII in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2013, 08:59 PM
  2. Unknown G code
    By cnczoneguy in forum G-Code Programing
    Last Post: 10-26-2012, 05:23 AM
  3. Unknown Spindle
    By bwb58 in forum Benchtop Machines
    Last Post: 12-16-2010, 08:19 AM
  4. unknown
    By ajmazzsr in forum Shopmaster/Shoptask
    Last Post: 06-06-2010, 06:32 PM
  5. Unknown steppers
    By wolfdagon in forum Stepper Motors / Drives
    Last Post: 03-12-2007, 01:52 AM
