585,877 active members*
3,081 visitors online*
    Sep 2009
    28
    How to enable 4th Axis in Path Pilot
    Hello Forum
    Just getting acquainted with the 4th axis on my Tormach 1100 series 3 with Path Pilot
    I know there is a configuration setting in Mach3 but.............I searched and searched but,
    how to enable the 4th axis in Path Pilot?
    Jul 2017
    70
    Re: How to enable 4th Axis in Path Pilot
    On the current version (2.8.1), go to the Settings tab and then choose the 4th Axis Rotary sub-tab in the upper left.
    Sep 2009
    28
    Should have stated in my original post. This is uncharted territory for me. I'll explore the 4th axis rotary sub tab.
    I'm attempting to use my mill to "turn" a round part on my 4th axis. I though that a special post processor was required to do that function.
    Thanks again!
    Apr 2012
    64
    You should download the free manual from Tormach, it will save you a lot of pondering.
  1. Enable Fanuc OM-D 4th axis
    By pinguS in forum Fanuc
    Last Post: 03-12-2024, 09:11 AM
  2. 4th axis disable/enable
    By davesnd in forum Fanuc
    Last Post: 07-04-2023, 08:38 AM
  3. Replies: 6
    Last Post: 04-02-2016, 11:02 PM
  4. Tormach 1100 seriers 3 running Path Pilot X Axis jammed up.
    By kenny calman in forum Tormach Personal CNC Mill
    Last Post: 10-17-2015, 07:49 PM
  5. V25 4th axis refuses to enable
    By JEST in forum BobCad-Cam
    Last Post: 10-02-2012, 12:38 AM
