585,981 active members*
4,140 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > Hello and where to buy belts for a DM2800?
    Sep 2012
    Hello all Dyna friends!
    My name is Göran and I live in Göteborg in Sweden.
    I have a 2800 that I converted to linuxcnc and Mesa electronics a couple of years ago. I haven´t been using it much but now I have moved it to a maker space and here it will be used more.
    But now the Y-axis belt snapped and the other belts looks like they will give up soon also. I'm going to replace all belts including the spindle belt.
    Does anybody know where to buy belts for this machine?
    BR
    Göran
    Jul 2009
    85
    Quote Originally Posted by mrJonasson View Post
    BR
    Göran
    For my dm4400m I had to pull the belts and measure them, then order replacements based on those measurements.
    From what I can tell almost all the mechanical components of these machines are fairly off the shelf standard things that are still available 25 years after production stopped on these machines.
    This certainly makes getting replacement parts much easier than it seems to be on other machines.
    Good luck
    Duke
    Nov 2019
    Re: Hello and where to buy belts for a DM2800?
    Hello Mr. Göran you can see the attached file information for the timing belt , assuming you still using the original ones from Dyna Mechtronics.
    Nov 2012
    365
    Hi RD,
    First, welcome to the forum!
    Unfortunately, you did not include an attachment in the post. Easy oversight
