584,833 active members*
5,749 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HAAS full table axis parameters
    Feb 2013
    10
    Hello,
    I have a VF-9. The machine can move in X and Y well beyond the table, but the machine will only let me cut in a relatively small area on the table. At a previous job, we changed parameters and got access to our full movement window for machining. We could machine toll the axis stroked out. This control is newer and different. I can't find where I would change those parameters. Does anyone know what to change so I can use the whole X and Y axis?
    May 2022
    14
    Re: HAAS full table axis parameters
    Hi, I bought a milling machine like your milling machine. Unfortunately, the parameters and all settings have been deleted. It does not run programs. If your machine model is vf-0. Please send me the general parameters and settings of the milling machine so that my machine can work again. Let me start, thanks, dear colleague [1993] vf-0
  1. HAAS TR160 Rotary table a-axis limit
    By subaueru in forum Haas Mills
    Last Post: 03-16-2012, 03:22 PM
  2. Haas Indexer as full 4th axis
    By WGJ in forum Haas Mills
    Last Post: 12-24-2009, 10:42 PM
