585,981 active members*
4,256 visitors online*
    Stepper driver set up
    Hi folks
    I have converted a ten high 6040 with s as new Ruida controller
    I have a couple of issues
    The machine has nema 17 motors
    I have ( purchased leadshine drivers 562 I think that came with a pair of nema 23
    Motors
    I don’t want to put the motors in as it is a lot of faff making new mounts ect
    The drivers I just can’t get running the motors ( nema 17 ) well
    The x is perfect but if I use same dip settings for y it’s awful I just don’t know where to start
    Anyone got a Ruida machine with drivers and nema 17 motors? If so can you give me your dip settings
    I also have a issue with laser
    It cuts fine but engrave is missing laser fire pulse I didn’t know if the oversized drivers are pulling to much power during an engrave
    Any help appreciated
    Nov 2008
    644
    Re: Stepper driver set up
    Stepper driver settings do two things. Sets the revolutions per step and how much power is used to drive the motor.
    I would ask it to cut a simple square then play with the units setting until it’s correct. You can also get it close and tune with software settings
    Power is a trade off between loosing steps at high accelerations and heating up the motor. Just lower power if it gets hot in long cuts.
  1. CL86T Driver Issues - Closed Loop Stepper Driver
    By Dreco in forum Stepper Motors / Drives
    Last Post: 08-22-2022, 10:08 AM
  2. Replies: 5
    Last Post: 08-01-2019, 08:25 PM
  3. What dip switches to set on Stepper Driver board?
    By johnnyt74 in forum Stepper Motors / Drives
    Last Post: 04-04-2017, 08:30 AM
  4. Replies: 7
    Last Post: 01-10-2015, 05:49 PM
  5. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 02:43 PM
