585,668 active members*
3,917 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco VM coolant Tank
    Feb 2016
    6
    I just took possession of a 2005 VM2 however it is lacking the coolant tank and pump. At one point the machine was equipped with the tank and auger however that was lost to the ages apparently. I will probably fabricate my own tank since we have a CNC plasma table and I can take it across the street to have it bent up before welding. Any owners here able to post pictures of the how of the factory drainage setup to get the coolant from the enclosure to the tank so I can have an idea how it was intended? There are two holes in the enclosure where the chips must have gone to the auger and I am planning on covering those with some perforated steel and then making a trough to move the coolant to the tank.
    Aug 2010
    101
    Re: Hurco VM coolant Tank
    Quote Originally Posted by Haggismaximus View Post
    that's how our VM1 does it. It's just a fine perforated steel sheet over one of the holes (the other is sealed), with a trough running over to the coolant tank.
  1. Bigger different-er coolant tank
    By zephyr9900 in forum Tormach Personal CNC Mill
    Last Post: 10-12-2012, 07:27 PM
  2. Coolant Tank
    By bookerandrew in forum Bridgeport / Hardinge Mills
    Last Post: 03-13-2010, 06:52 AM
  3. Coolant Tank Paint
    By dkaustin in forum Tormach Personal CNC Mill
    Last Post: 01-24-2009, 10:14 PM
  4. vf-3 coolant tank
    By GENMACH in forum Haas Mills
    Last Post: 07-17-2007, 09:04 PM
  5. Coolant Tank
    By GITRDUN in forum Haas Mills
    Last Post: 09-15-2006, 06:00 PM
