584,866 active members*
5,142 visitors online*
Results 1 to 17 of 17
    Feb 2015
    18
    Spindle Question
    Started hearing a buzzing type sound when starting and stopping the machine. Probably there when running too. A have an Avid stock 2.2 air cooled spindle. Pulled the cap off and found the green fan wheel had some of the fins either broke off or wore down some way. Could this be the source of the noise? Can I buy (from where) just the green plastic fan wheel?
    Mar 2017
    250
    Re: Spindle Question
    I could see that balance being off could do that. Are there any small shards stuck to the fan still that could be rubbing?
    On another note, I should figure out a method that does not allow that to happen to mine. Maybe some wire mesh that doesn't restrict at all. Otherwise, you may be able to purchase the fan itself from the manufacturer. Just in case it fully breaks apart.
    Sent from my SM-N960U using Tapatalk
    Quote Originally Posted by honesttjohn View Post
    The noise should be come from the broken fan.
    If need to replace it you need to know its model name and the spindle motor model name and brand.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Mar 2009
    1982
    it looks like the fan has no separate drive? Is it driven by spindle directly?
    Then you have the tool tip vibration, making bad surfaces and raising risk of tool breakage.
    You can order 3D print of the plastic part in worst case.
    You can install independent fan instead.
    Mar 2017
    250
    It is powered by the spindle. It's branded but hard to find much info about the spindle at all. However, I think it could be possible to get a fix. Avid might be able to hook that up through the vendor if you ask them.
    Feb 2015
    18
    I sent Avid an email last nite (Suday) and got a reply today (Monday). They had an old spindle that they are pulling the fan off an sending to me. The also are not using GMT spindles anymore, but have gone to Hiteco, which will fit in the same mount and are wired the same. You only have to change some VFD settings. Can't ask for anything better than that.
    Mar 2017
    250
    That sucks for me. I only bought my spindle less than a year ago...
    Feb 2015
    18
    Trying to find parts for the GMT spindle is a real bear.
    Nov 2014
    729
    It's good that they're taking care of you, John. That sounds like excellent customer service!
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    15362
    You have to find out what caused that to happen or the same thing is going to happen
    Mactec54
    Jan 2018
    1516
    Do you think it might be a balancing issue?.
    Friday afternoon built motor?.
    Keep our fingers crossed for him.
    Feb 2015
    18
    It's worked for 3 years without problems. I'm guessing cheap Chinese plastic either started to give out or wood chips got stuck in there someway. But several fins were affected.
    15362
    No such things as cheap plastics for an injection molded part like this that runs at high RPM, it would of failed in the first minute if it was made from cheap plastic, where the pieces are missing it hit something
    Mactec54
    I had the same thing happen to me only 6 months owning approximately the fan jus exploded after running for 15 minutes off and on
    Ill have to contact avid hope they can fix it
    Apr 2004
    323
    This just happened to my Hiteco on Friday. About a month old. Waiting to hear back from Avid, but I guess I should find a source for spare fans as well.
    15362
    Quote Originally Posted by Kosh View Post
    Thats a different fan from the other ones that failed, I guess they are all poor quality from this manufacture
    Mactec54
    Jul 2018
    6254
    Hi - Seems many issues with Chinese plastic moulded stuff at present. They seem to leave something out or use additives to reduce cost that impacts performance. Same with nylon tapes in yacht industry. For many years these lasted many many years but now they die within a year. Supposed to be same material from same supplier but clearly not. Peter
  1. Replies: 3
    Last Post: 11-19-2019, 11:03 AM
  2. Spindle question Control spindle speed via UCCNC
    By sierradays in forum UCCNC Control Software
    Last Post: 09-25-2019, 12:08 PM
  3. Spindle question
    By Analias in forum DIY CNC Router Table Machines
    Last Post: 04-23-2012, 02:51 AM
  4. Newb Question: Difference Between 40 Taper spindle and a 50 taper spindle
    By AndrewJP in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2010, 12:00 AM
  5. Spindle Question
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 03-12-2007, 03:22 PM
