585,585 active members*
3,679 visitors online*
Thread: HELP…..
    Sep 2003
    1469
    HELP…..
    I purchased Gerry’s 2010 Screenset a year or so ago, after hit and miss setting the Z axis zero position manually for over 12 years, I was so looking forward to have that set automatically saving me much time and making my use of the CNC much more accurate.
    Everything went fine through pages 1, 2, and page 3 down to “Auto Zero Setup”, where your instructed to go to pages 9-14. That’s where the instructions broke down for me.
    I have installed homing and limit switches on my CNC as shown in the below photo, but none have been powered up, it also shows the port and PIN numbers the switches are connected to on the BOB, I have never used homing, limit switches, Machine Settings, or Material Offsets, which is a weakness in understanding the information in setting up and running the software.
    The 2010 screen is displayed on my screen and I successfully use many parts of it in the “manual” mode. I so look forward to be able to click on any of the screen hot spots and have the Auto Z Zero run and many of the other things that will make my CNC use more accurate and fun to use.
    I really would love for someone’s assistance to help me complete the installation of this valued software. However if three or four people try to help me at once I don’t think that would work, as each would have their own sequence and method which I’m sure would confuse me more. So I’m really not sure how to ask for help.
    Any suggestions, on how I can complete the installation?
    Thank you.
    Hager
    15362
    Re: HELP…..
    Quote Originally Posted by Mr.Chips View Post
    Thank you.
    Hager
    I would say the best person would be Gerry himself then
    You should have everything working like Home switches Etc. being able to home your machine is an important step, then all your X Y Z work offsets G54 Etc. are part of your machines Homed position coordinates
    Once you have Home switches setup you can setup soft-limits, limit switches are not needed if you can setup the soft-limits, Warning soft-limits don't work unless the machine has been homed so if you where to move your machine around before Homing you could crash your machine without Limit Switches so your choice if you have limit switches or not
    Mactec54
