585,722 active members*
4,396 visitors online*
Results 1 to 6 of 6
    Feb 2004
    304
    How to keep Z axis down with VoluMill
    Hi All,
    Is there a way to keep the z-axis from raising during the non-cutting positioning part of the cycle in Solidworks?
    Kevin
    Jan 2018
    1516
    Re: How to keep Z axis down with VoluMill
    Quote Originally Posted by kevincnc View Post
    Hi All,
    Kevin
    Are you using HSM?.
    I recall in Inventor it was to do with the "maximum stay down distance" value in the last tab (that comes after the finishing passes etc settings).
    If you have a lift/retract distance to next cut of say 80 and you set the above value to 90 the tool will stay down.
    This is NOT advised if the said move is a RAPID!!. (unless tool will not be going through any stock).
    It might not even be the same cam program as yours anyway, but I would say it would be marked as a "stay down" type setting still.
    Feb 2004
    304
    Quote Originally Posted by dazp1976 View Post
    Are you using HSM?.
    It wasn't a problem when I used HSM, but now using the built in Solidworks CAM, I can't find it.
    Kevin
    Mar 2016
    323
    In this software it is not so obvious that they gave such option. It is very poor.
    Nov 2017
    44
    You can use G99 in Fanuc cycles. It works.
    Feb 2004
    304
    Thanks for the replies, and here is the answer. Set Floor Clearance in Volumill Settings to 0.
  1. VoluMill of ZW3D
    By Seanyaohan in forum ZW3D CAM
    Last Post: 09-19-2018, 07:19 AM
  2. VoluMill
    By 5x-TSolid in forum Uncategorised CAM Discussion
    Last Post: 09-11-2018, 04:41 PM
  3. VoluMill in BobCAM - Free VoluMill Available
    By gsaisselin in forum BobCad-Cam
    Last Post: 09-10-2018, 04:26 PM
  4. Anybody using VoluMill with FC?
    By rory71 in forum FeatureCAM CAD/CAM
    Last Post: 10-11-2012, 01:47 PM
  5. Experiences with VoluMill?
    By nasdaq in forum GibbsCAM
    Last Post: 02-02-2011, 07:40 AM
