Tom
Thank you so much for the help , i think i have it where it is workable , now to set it up in Kmotion.exe
i have set up M3,M4,M5 and S in the tool setup , using your example in the CSS folder and the Motor starts and changes direction . but it doesn't Stop or display speed.
i have the FACTOR set at 50 holes*4 edges = 200/60 or should i be using a different format as i read somewhere 1=3750 or 20157 = 3750
i think i have read so many posts and guides now that i am confusing myself.
I have also used the basic control example for spindle control , exactly as in the Manual just changing the bits to 154 and 155 and DAC =0
the spindle also starts both CW and CCW but doesn't stop or display speed . when i start the spindle it also goes full speed even if i set S=500 in the gcode
(Edit Png shows min 0 and max -2047 ,, i have tried with these values transposed and outcome is the same)
regards
Sean
