586,011 active members*
5,169 visitors online*
Page 1 of 2 12
Results 1 to 20 of 35
    May 2006
    309
    Spindle gets hot.
    I bought a new Taig mill from Deepgroove and the spindle doesn´t run easily and it gets very hot after just some minutes on 8000 rpm. It doesn´t help to loose the nut at the top, so I need to know if this is normal for new spindles and if it will improve after I have used it for a time. Or could this damage the spindle in any ways?
    Are there anything to do with a problem like this?
    15362
    Re: Spindle gets hot.
    Quote Originally Posted by jaru-eri View Post
    If the temperature gets above the Bearing max it will damage the Bearing and shorten it's life
    Mactec54
    Jan 2018
    1516
    I had that one time on a mini mill after changing bearings.
    Had the preload too heavy. This could be the cause.
    But when I loosened the top nut I also had no difference.
    The reason: The bearing was a tight fit on the shaft so stayed true.
    Fix was: Undo the nut a bit and hit the shaft top. The bearing shifted which looseened the preload. Then started the gradual tightening process again until I got it right.
    May 2006
    309
    Quote Originally Posted by dazp1976 View Post
    I tried to do that but it didn´t rotate better. I´m now running the spindle unloaded at a very low speed and will see if that helps after som hours.
    Nov 2013
    4372
    if its new claim under warranty....it should work straight out of the box no problems.
    Craig
    Mar 2009
    1982
    address supplier with your claim. The spindle should run very easy. Check the static runout with micrometer, check with spindle specifications.
    May 2006
    309
    The problem is that I bought it from an ebay dealer (deepgroove) and even if he accept a return, the shipping cost from norway to USA is very expensive, so it will maybe be a cheaper option for me to disassemble the spindle block, check the bearings and maybe replace them.
    Mar 2009
    1982
    right.
    It's possible, that bearings are still good. Maybe it's just enough to assemble it back properly.
    15362
    Quote Originally Posted by Algirdas View Post
    right.
    They can never be assembled correctly, the design is the problem they use a regular Deep Grove Bearings and these are not suitable to be pre-loaded, the design is as cheap as you can get and anyone that buys a machine with a spindle design like this can expect these kind of problems, the preload nut they use can be adjusted but even this is hit and miss it is what it is a poor design for a spindle
    Mactec54
    May 2006
    309
    Which spindle will then be the best alternative to use together witn a consew motor?
    Jan 2018
    1516
    right.
    This is an interesting read on spindle / bearings
    https://axotron.se/blog/changing-spi...taig-cnc-mill/
    15362
    You could redesign the one you have by using precision angular contact Bearings, you would have to make a spacer to go between the ( 2 ) Bearings this spacer you machine to give you the right amount of Preload Here is a spindle I made recently
    And another spindle I built some years ago on the Zone, to give you an idea of how you could change the spindle you have with just bearings and a spacer
    Or even just adding a spacer between the Bearings you already have, this will then not allow the preload to change once you have made the spacer the correct size
    https://www.cnczone.com/forums/cnc-w...dle-build.html
    Mactec54
    Jan 2018
    1516
    Nice set of parts. Looks like a good bit of precision work (and probarbly expensive).
    May 2006
    309
    Do you think this spacer is an option or is it already installed inside the block I have?
    https://taigtools.com/product/er-spindle-cartridge/
    15362
    Not expensive if you can design and machine the parts yourself, this was all done in my home shop
    Mactec54
    15362
    So that looks promising but it would have to have 2 Spacers ( 1 ) on the inside of the Bearing races and ( 1 ) on the outside of the Bearings like you can see
    So is hard to tell what they have done there, without a parts drawing if it has a spacer on the inside of that outer one then that would work
    Does your spindle already have this I would not know only the manufacture would know this, if it has then the inner spacer may be to long it would only be tenths of ( 1 ) thousandth's or a few microns to come of the center spacer
    It all depends how they are preloading the Bearings it could be the outer spacer or the inner spacer if they have one, so if you where to take it apart after notifying the manufacture, you would measure the length of the spacer or spacer's what ever the number is ( 1 ) will be longer than the other
    Mactec54
    May 2006
    309
    Will it be possible to use a spacer that has been made of pvc or other plastic materials or do it need to be steel? And do you know the exact lenght of the spacer that wil be suitable for a taig spindle block?
    May 2006
    309
    I have been in contact with Taigtools but they don´t answer me anymore. They asked me to send a picture of the spindle and nut in the housing and I sent a picture where it also show that it was driven by a consew motor and maybe that´s the reason for not answering me anymore. Anyway I think it´s a very bad customer service they offer.
    15362
    No that would not be possible for the spacer to be made with Plastic of any kind, it must be made with steel or similar materials, there is no way to know the exact length every Bearing Preload like this can be a little different
    Mactec54
    The problem is likely that Taig is the manufacturer and you bought from deepgroove who is supposed to provide you with the customer service. He sells at the deepest discount possible but there is a risk you take when paying bottom dollar… if things go wrong he’ll ghost you. At least that’s what he did to me years ago when he paired the wrong motors with a xylotex board and I couldn’t get over 10 IPM feeds without missing steps.
    That said, couple questions… how are you measuring RPM? The spindle is able to do 10k but the sealed bearings get too hot much above that. The seals are what generate most of the heat. Without seals they have a higher limit. Have you placed a tach on the actual spindle pulley?
Page 1 of 2 12
  1. Spindle getting HOT
    By CEStanley in forum Benchtop Machines
    Last Post: 07-30-2020, 04:11 PM
  2. Spindle is getting HOT! Problem?
    By F15pilot in forum Spindles / VFD
    Last Post: 07-09-2015, 10:46 PM
  3. Replies: 0
    Last Post: 10-27-2014, 09:44 PM
  4. X2 spindle getting hot
    By SScnc in forum Benchtop Machines
    Last Post: 06-12-2014, 02:43 AM
  5. Spindle Hot To Touch
    By Cory in forum Haas Mills
    Last Post: 03-29-2008, 04:21 PM
