585,700 active members*
3,832 visitors online*
    Nov 2008
    16
    Help with router config. settings
    I am confused. Config settings are not controlling my router. Output settings: the router relay runs off pin 17. First, I don't know if should be wired "normally open" or "normally closed". The relay is powered as soon as I turn on the machine and will not turn off So, I don't know which switch in the config. turns it off. If I look at diagnostics I see the correct led is lit to switch on the router. If I switch the wiring on the relay to normally open then the rpoutret will not start. The other axes work fine. So, I know this is an output setting somewhere in the config. Help! (This machine was working fine until I disassembled it and got it running in a different location.)
    Jan 2018
    1516
    Re: Help with router config. settings
    Quote Originally Posted by notselrach View Post
    If it's Mach3.
    The relays can sometimes be a pain to get right.
    Normally on a lpt bob with relay on 17 I set up as:
    Spindle in 'motor outputs' DIR as 0.
    In 'outputs' I set desired output as pin 17.
    'Spindle setup' M3 to desired output, M4 to a fake/empty output.
    Now on the M3 output toggle 'active high' / 'active low' and this should see the relay go on/off. Select the desired action. Wire up NC/NO as appropriate.
    Then it's a case of fiddling until you get it right.
  1. Dip Switch and Config Settings Questions
    By aero1310 in forum Stepper Motors / Drives
    Last Post: 09-11-2018, 02:57 PM
  2. with my TB6560 board config/Mach settings
    By swinds in forum CNC Machine Related Electronics
    Last Post: 01-16-2012, 04:28 PM
  3. mastercam x router config to scm tech z2
    By grayedano in forum Education - Teachers and Students Hangout
    Last Post: 01-16-2012, 08:31 AM
  4. Config settings help
    By tigman250 in forum Mastercam
    Last Post: 03-24-2011, 01:21 PM
  5. config settings for mach 2
    By fidia in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-04-2007, 11:18 AM
