586,011 active members*
4,097 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Aluminium bar stock for swiss machining - material bending issues
    Nov 2019
    5
    Exclamation Aluminium bar stock for swiss machining - material bending issues
    Hello,
    We have a part out of 6061-T6 aluminium, which requires Swiss machining in guide-bush mode. We got several lots of material from India, but so far the material lots have problems like bending or BHN (hardness) less than 85 (min. required value).
    All of this is resulting into either too much vibration or not a matte finish of the final part, despite taking finishing cuts.
    I need help with recommendations on quality aluminium material suppliers from Asia or Europe, if anyone has any idea about the same.
    Our required size is 0.748" OD (19 mm). What kind of OD tolerance should we ask for our suppliers for Swiss turning? We usually order materials under +/- 0.0002" (+/- 0.05 mm) tolerance on the diameter for Brass and Stainless.
    Thanks!
    Jan 2013
    126
    Re: Aluminium bar stock for swiss machining - material bending issues
    I would say you would want to maintain the same tolerance of the material that you do for brass and aluminum. I cannot help with supplier info I am in the US
  1. Replies: 3
    Last Post: 06-17-2016, 04:55 PM
  2. Bending rectangle aluminium bar
    By Luis Van Damme in forum Bending, Forging, Extrusion...
    Last Post: 08-24-2011, 10:02 PM
  3. Minnesota Metal Suppliers? Swiss Bar-Fed Material
    By pneumadyne in forum MetalWork Discussion
    Last Post: 04-05-2010, 10:23 PM
  4. Bending 1/8" square Stainless Bar Stock
    By Bingster in forum Bending, Forging, Extrusion...
    Last Post: 09-01-2009, 03:11 PM
  5. Swiss Material Requirements for Centerless Ground Stock
    By tejano4life72 in forum CNC Swiss Screw Machines
    Last Post: 02-18-2009, 05:33 AM
