585,585 active members*
3,794 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Machining center tool command
Results 1 to 9 of 9
    Oct 2009
    114
    Hi every body
    We bought a second hand horizantal machining center. It doesnt accepts. T tool number command. It accepts TF command. Is there a paramter to change to T command system
    Thanks for help
    Mar 2009
    1982
    Re: Machining center tool command
    Pallet changer?
    is it OSP driven?
    Error message?
    What is wrong if you use TF instead of T command?
    Oct 2009
    114
    When we g?ve T3M6
    It gives 2336 Alarm B Falscher T befehl FFFFFFFF
    Quote Originally Posted by MCR-B II View Post
    Hi every body
    Thanks for help
    What is the CNC controller model?
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Mar 2009
    1982
    Stupid question, but still. Did you set the tool 3? Check the tool table if there are tools set into magazine pockets. Generally the pocket number is not the tool number, you know that?
    Dec 2008
    3109
    Do you have any library files on the machine ?
    If yes, check if a G/M code has been assigned for a better toolchange.
    ie. Checks if toolchange is required, & not in the spindle, or a different tool is in the pre-toolchange position.
    Mar 2009
    1982
    oh yes, you need to check the number of ATC sequence. The tool change command is accepted at dedicated steps only.
    Oct 2009
    114
    Thanks for all
    Machine has Tool id system. ATC tool setting is different than others. how to set a tool to machine. There is a photo. here
    Attachment 467648
    Mar 2009
    1982
    It could be done in manual mode. Generally, It's very good to do step by step reading the manual. The idea is:
    1. Open door
    2. Push the button to open tool clamp
    3. Manually place the tool into spindle nose
    4. Push the button to clamp the tool
    5. Key-in the tool description. Tool number is absolutely necessary, all the rest according the situation
    6. Check if the next tool is "0"
    7. Push the button manual tool change.
    Tool goes to magasine ( you don't care to which pocket )
    This procedure is good for setting tools when you do measure offsets at the same time.
    I can't tell if the description of procedure is correct here, Door open close sequence can be different. The push button for tool description in the manual mode and so.
    Maybe a little easier is to set the tool into magazine and tell in the parameters the tool number in that exactly pocket. After that is possible to call the tool into spindle.
    Should be described in detail here in this forum in the posts at about 2002. Maybe someone will attach the original procedure description taken from operators manual.
  1. Replies: 0
    Last Post: 12-05-2020, 05:15 AM
  2. Replies: 0
    Last Post: 11-03-2011, 12:39 AM
  3. Siemens 840D on Deckel machining center. Locked in middle of tool change
    By Chuck - Detroit in forum Controller & Computer Solutions
    Last Post: 10-27-2009, 11:47 AM
  4. excel machining center - tool change issues
    By CVTE66 in forum CNC Machining Centers
    Last Post: 11-19-2007, 01:27 PM
