585,775 active members*
4,047 visitors online*
Results 1 to 10 of 10
    Question Motor X doesn't work the way it should
    Hello everyone,
    I have 50W CO2 Laser Engraving Cutting Machine Engraver Cutter (from China)
    The software I use is thunder Laser
    The controller I have is ruida.
    I have had this laser for less than a year and suddenly X motor doesn't work as it should.
    I have tried to check the setting in vendor but it made no difference (I have 3 more lasers like this so I copied the vendor settings and paste it in this laser machine but it still didn't made any difference) also I have replaced the X motor thinking that it's broken but after I put new motor it had the same problem.
    I have replaced X micro-step drive and mainboard with the new one but it made no difference.
    I change the pc thinking that it might cause the problem but nope :I
    I tried to look for the dirt in X motor path or belt thinking that maybe this is the problem but I couldn't find anything.
    the belt is not loose either so I have no idea what it could be.
    can anyone help me with this problem?
    Pov'
    Nov 2008
    644
    Re: Motor X doesn't work the way it should
    What exactly is the X axis doing?
    Did you try swapping the X and Y axis to see if the problem follows?
    Quote Originally Posted by Dean448 View Post
    thank you for your messege
    the motor crunching and it doesn't go as smooth as Y axis
    even when I switch the parts it the problem stay on X and not Y so strange
    Nov 2008
    644
    Here’s my suggestions:
    Run motors off the machine. If they are smooth then problem in slides
    Swap just motor leads. Problem stays then issue not in motor.
    Swap the XY leads from the controller to the motor drives. Problem stays then issue with controller Problem moves then issue with drive.
    Put back to normal between tests.
    I have tried to take the belt of the motor and press the bottom to see how it mos but it does the same thing.
    Nov 2008
    644
    Ok so you disconnected the belt and it does the same thing. Now swap the X and Y motor connectors. Does the noise go to Y or stay with X?
    the motor X works the same way as before it made no difference if it been plugged into Y motor controller or no.
    could it be software that creating the problem?
    and motor Y controller with X motor controller works perfect.
    Nov 2008
    644
    If everything driving problem X is now connected to Y, and the problem is still with X then the problem must be in X motor, or it’s wiring or connector.
  1. My Step Motor doesn't work I need replacement Info
    By miranto in forum Stepper Motors / Drives
    Last Post: 07-31-2015, 12:21 AM
  2. G10L50 doesn't work
    By martyc@blumlmt in forum Fanuc
    Last Post: 09-05-2012, 09:53 PM
  3. BT doesn't work (MAHO)
    By FloBue in forum Philips
    Last Post: 10-19-2011, 07:01 AM
  4. Honing doesn’t work out
    By tw_inaktiv in forum Autodesk
    Last Post: 07-10-2008, 02:19 PM
