586,024 active members*
4,420 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > M62 to assign output number 4 to fire the torch
    Mar 2021
    hi Newbie here. having completed my table i am now in the process of commissioning. as i am new to g and m code
    i am on a fairly steep learning curve. I am using a planetcnc USB MK3/4 With planetCNC TNG.I have wired the trigger switch for the plasma to output number 4 but i am having trouble getting my head around using m code to assign output number 4 to be trigged either in the program or in the Post processor (THC floating z axis) ie the code syntax and where to position it in the PP/ Program
    any help would be gratefully accepted. thanks
    Jan 2016
    19
    Re: M62 to assign output number 4 to fire the torch
    Hello Newbie,
    did you ever type M62 P4 Q1 in the MDI?
    This switches output 4 to "on".
    M62 P4 Q0 to "off".
