585,762 active members*
4,140 visitors online*
    Jul 2021
    3
    Lathe conversion
    Hi
    I will convert a Bernardo BQV550 to CNC.
    Like to use KFlop + Kstep for controller
    How to connect an ancoder for Spindle to KFlop?
    Which Encoder should be used?
    Is it possible to run 2 KFlops in one PC, 1 for milling machine (allready exists) and a second for the lathe?
    BR
    Gerhard
    May 2006
    4045
    Re: Lathe conversion
    Hi Gerhard,
    Its best to use a differential encoder. But KFLOP+KStep doesn't have any differential encoder inputs. So you might use a 3rd party differential receiver such as this. This might be then connected to a KFLOP Single ended Encoder input ie JP5. Encoder resolution should be such that at max RPM KFLOP's maximum cout rate of 1 million quadrature counts/sec is not exceeded.
    That should be possible. When launching KMotion/KMotionCNC which KFLOP to be used needs to be specified as a command line parameter USB Location ID. See here.
    TK
    http://dynomotion.com
    Jul 2021
    3
    Hi Tom,
    is the second KFlop also possible if I use your MACH3 plugin?
    BR
    Gerhard
    May 2006
    4045
    No. Mach3 is obsolete and unsupported. Consider using our free KMotionCNC.
    TK
  1. Single Purpose Lathe Conversion-Gang Lathe Setup
    By Aaron Moss in forum CNC "do-it-yourself"
    Last Post: 08-19-2020, 04:12 PM
  2. Lathe conversion
    By ghack in forum Centroid CNC Control Products
    Last Post: 11-07-2014, 08:08 AM
  3. Lathe conversion
    By ArtCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-28-2011, 06:47 PM
  4. Lathe conversion
    By lokii in forum Vertical Mill, Lathe Project Log
    Last Post: 03-20-2011, 09:59 PM
  5. Anyone done a C6 lathe conversion
    By mcraig79 in forum Mini Lathe
    Last Post: 11-13-2008, 11:38 PM
