585,886 active members*
6,019 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > Which Controller or Software to use? Finding and remembering centre points for ....
Results 1 to 13 of 13
    Aug 2020
    12
    I have done some automation using a dedicated controller to achieve basic G-Code based stuff but that sums up the depth of my experience.
    Now I have decided to build a machine that requires some more complicated task, such as knowing an approximate centre of say 3 holes with 3mm +/- tolerance.
    The machine would have to visit each hole and using a probe would have to find the centre of each hole and register the x and y coordinates to the accuracy of say 0.01mm.
    These coordinates would then be used later in the job/process.
    The rest of the tasks are easy, but this above is something I like to find the best controller/software solution for.
    It would be also important to be able to access remotely to
    It would be good to be able to customise the operator interface
    The machine would have 3 axis, X and Y for horizontal and Z for the spindle
    What would be the best suited for this type of work?
    TIA
    Tom
    Nov 2013
    4370
    Re: Which Controller or Software to use? Finding and remembering centre points for .
    I have used Mach for years, first Mach3 and parallel port motion controller, and for the last six years Mach4 and an Ethernet SmoothStepper motion controller.
    Either Mach3 or Mach4 would do as you require, and more besides. Its not so much that they are adequate but both so much more capable.
    Of the two I prefer Mach4, its careful and modular design using Lua as a scripting language allows for very flexible and comprehensive customisation. It's
    ready facility to be customised is perhaps its greatest strength and compares well or better than most of it competitors in that narrow regard.
    Craig
    Jan 2018
    1516
    Quote Originally Posted by silver_fx View Post
    TIA
    Tom
    How many lines of code would it be?.
    Mach3 can do 500 lines in demo mode (free).
    Just something to note.
    Dec 2013
    5717
    TIA
    Tom
    Is this for an industrial assembly line type application?
    A Galil Motion Control unit would be my first choice for a controller, most likely a DMC-4030, then just write the the operator interface software for it using your favorite development software. That way you have 100% control over the entire process. Overall this seems pretty easy and painless.
    I guess it depends on the budget you have for this project.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2020
    12
    Thanks vm, Machx is certainly tempting since it is windows based, which I heard is also the downside of it. In any case Mach3/4 is a good candidate
    Aug 2020
    12
    Well, that is something I am not sure of. Really the only complicated stuff is the centring - finding and recording each centre point which I have no idea how is it done. G-Code? else?
    the rest would be a lot less complicated.
    Nov 2013
    4370
    Mach4 has quite a range of probing functions built in. For example the screenshot is of the Bore/Boss probing tab.
    The probing routine is written as a script which is viewable and editable so you can customise it to suit....although its entirely probable
    you wouldn't have to modify anything.
    Craig
    Attachment 467638
    Jul 2013
    my 2 cents of contrubution.
    Take a look here:
    https://www.theremino.com/en/downloads/automation#cnc
    Leo
    Aug 2020
    12
    Thanks, that is certainly worth considering
    Craig
    Attachment 467638
    Aug 2020
    12
    Thanks Jim,
    I am building a boring machine that needs to bore 3 or 4 cylinders. The automatic repositioning and centring will certainly be a big progress but I also like to make it so the boring diameter can be electronically (digitally) controlled ....this will be an even bigger challenge
    Considering the Galil Motion Control Unit, does it come with an API? as you said I can use my choice of develpment software (language I assume) ?
    TIA
    Tom
    Dec 2013
    5717
    Thanks Jim,
    TIA
    Tom
    Yes, the Galil comes with an API. Programming the Galil itself can be done in any text editor, or the free Galil software. The API has examples for C++, C#, and VB.net. Very easy to work with. I use the free version of Microsoft Visual Studio, VB.net for my programming. I think Galil also has drivers for Linux. I'm running several CNC machines with Galil products, as well as using them in other industrial applications..
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2020
    12
    Thanks Jim, When can I find references/samples of the Galil API?
    Dec 2013
    5717
    https://www.galil.com/downloads/api
    They may ask you to set up an account to download. They won't spam you, just a news letter once every couple of months.
    Jim Dawson
    Sandy, Oregon, USA
  1. Finding the centre of a small countersunk hole
    By Iano in forum Benchtop Machines
    Last Post: 06-19-2011, 11:44 PM
  2. Finding exact centre of 3mm hole
    By boxmaker in forum Benchtop Machines
    Last Post: 11-19-2010, 02:46 PM
  3. Another Aussie Adventure in Optical Edge/Centre Finding
    By Greolt in forum Mach Software (ArtSoft software)
    Last Post: 04-01-2008, 09:48 PM
  4. Finding the centre of an arc
    By Robin Hewitt in forum G-Code Programing
    Last Post: 03-28-2008, 02:02 PM
