585,970 active members*
3,906 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > Controller NVUM v2 4-axies hangs after a while
    Aug 2021
    Angry Controller NVUM v2 4-axies hangs after a while
    Hi there,
    I have some serious problems with (i think) nvum v2 controller. When machine works for example for couple of (2-3) hours theres magic happens and instantly stops stepper motors, hangs communication with my PC, and going to be no operative anymore. My PC works perfectly with mach3 software but shows "device is not ready".
    I've restared all devices, driver and nothing happend. For couple of hours controller started to work as normal. Device is not overheated (I’ve mounted extra fan near by).
    What should I do now? Need to replace nvum driver ?
    Nov 2013
    4372
    Re: Controller NVUM v2 4-axies hangs after a while
    NVUM has been caught selling pirated copies of Mach3 so has been blacklisted on the Mach3 forum. If you can't get any help from the manufacturer then
    you are likely on your own.
    Craig
    Aug 2015
    142
    Re: controller nvum v2 4 axies hangs after a while
    Nvum is a piece of XXXX, dont buy that , for the money u can buy a real solution like uc300 eth , or 400 eth , no usb , no interference , no freeze ...
    Jan 2018
    1516
    Don't reinstall driver if you don't have the original .BIN file.
    You will brick it and throw it away.
