586,009 active members*
4,780 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > HAAS SL-20 ALARM 292 320V POWER SUPPLY
    Nov 2019
    Hi all,
    i have a Haas SL-20 2007, when i power up a have the alarms below:
    102 SERVO OFF
    292 320 POWER SUPPLY FAULT
    107 EMERGENCY OFF
    There in no other alarm and it doesn't come off when I cycle the power.
    when I measure the dc power output is 325v and the DC BUSS in the dignosys is the same 325v
    when called my HFO (ho is 600km away ) he told me to change the regen and i did it without any change.
    do you have any ideas please???????
    thank you in advance
    May 2011
    308
    Re: HAAS SL-20 ALARM 292 320V POWER SUPPLY
    I’m not an expert on this but…
    Will the error clear if you hit the reset button rapidly 3 or 4 times in a row?
    What is your parameter 294 set to? Is it 270 ? You could temporarily try setting this value to 0 and see if that works after a power cycle. The vector drive might be reporting the wrong voltage to the maincon.
  1. 320V POWER SUPPLY ALARM HASS d
    By Sylwester1 in forum Haas Mills
    Last Post: 08-08-2018, 11:54 AM
  2. Error 292. 320v power supply fault
    By rshead1 in forum Haas Mills
    Last Post: 01-18-2016, 09:32 AM
  3. TM1 with undervoltage alarm on 320V power supply
    By jolulank in forum Haas Mills
    Last Post: 06-04-2014, 11:13 PM
  4. Alarms at power up, 320v power supply fault?
    By locash in forum Haas Lathes
    Last Post: 01-10-2012, 06:35 AM
  5. TM1 320V Power Supply Blues
    By KevinWilkins in forum Haas Mills
    Last Post: 02-16-2011, 10:32 PM
