585,992 active members*
6,052 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mitsubishi controls > Drip feed Meldas 520AMR Info and Settings needed.
    Working with a new to us 1997 Mighty Comet 850. Its rocking a Mitsubishi Meldas 520AMR.
    I have read and searched all over and I cant seem to find the correct settings to get Drip feed/Tape mode work. Seems like every software I have dnc4u, Preditor, NCNet...All have different terms for each setting. I can send and receive programs to memory just fine. If anyone can go over the parameters and device settings along with a solid program to use for drip feeding along with settings would be a HUGE life saver!!
    Huge thanks!
    Aug 2009
    1573
    Re: Drip feed Meldas 520AMR Info and Settings needed.
    Quote Originally Posted by Turbo_Sally View Post
    ...it maybe your serial cable setup. USB to Serial adapters do not play well usually with DNC Is your cable homemade 3 wire? Use a fully wired Null Modem type serial cable (PC to PC) if, possible.
    https://en.wikipedia.org/wiki/Null_modem
    This could be an issue. I have been using a laptop with a USB to serial adapter. I had been just assuming that if Sending to and from machine memory worked, it would work or drip feeding. The cable Im using was given to us by the previous owner.
  1. Meldas 520 AMR Drip feed
    By metalmover in forum Mitsubishi controls
    Last Post: 12-03-2022, 08:08 AM
  2. Replies: 0
    Last Post: 01-16-2019, 10:01 PM
  3. Drip feed Meldas 50?
    By james3232 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-13-2017, 01:25 PM
  4. meldas 500 drip feed problem
    By Bada Bing in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-08-2016, 08:16 PM
  5. Meldas M300 DNC or Drip Feed
    By slapnpop in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-21-2007, 06:16 AM
