585,997 active members*
5,027 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach3, Smoothstepper, Gecko 540: Probe stopped working
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Sep 2005
    371
    Re: Mach3, Smoothstepper, Gecko 540: Probe stopped working
    @ Mactec54
    Sorry, I didn't answer your question about fixing the grounding issue. I simply went into my 220V outlet housing and added a wire from the ground side of the outlet to the back of its case. This grounded the whole machine and I no longer was getting any voltage across from the enclosure to the gantry and bed.
    I removed the wire last week thinking that might have been causing a ground loop and retested. Oddly, I no longer have voltage crossing between the two.
    I'm guessing something else was causing it but I did tighten down every terminal I could see and remember and the problem has gone away.
  2. #22
    Aug 2005
    1092
    Quote Originally Posted by Dean448 View Post
    Do you know what an out of warranty repair for blown G540 inputs will cost? Wonder if it’s just a component on the motherboard that can be replaced?
    The motherboard can be purchased if faulty and replaced, as can each of the four axis drives.
    https://www.homanndesigns.com/index....roducts_id=281
    Cheers
    Peter.
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
  3. #23
    Sep 2005
    371
    Didn't know we could purchase the motherboard!
    I'll squirrel that tidbit of information away! Thnx
  4. #24
    15362
    Quote Originally Posted by Vogavt View Post
    @ Mactec54
    Grounding everything is important you should have one place in your cabinet that all Grounds are connected ( Star Ground ) this can be a stud or best a Ground Buss
    So all Ground wires must go to the Ground Buss there is no chance of a Ground loop, your cabinet must be Grounded to the Ground Buss along with everything in your cabinet that has a Ground requirement
    Mactec54
Page 2 of 2 12
  1. Enclosure for Gecko 540 and SmoothStepper - both in same box?
    By dixdance in forum CNC Machine Related Electronics
    Last Post: 03-23-2021, 08:29 PM
  2. Replies: 1
    Last Post: 11-13-2020, 07:39 PM
  3. Gecko 540, mach3 and limit switches.
    By Vegabond in forum Mach Wizards, Macros, & Addons
    Last Post: 03-06-2011, 12:11 AM
  4. gecko 540 with mach3
    By meck11 in forum Gecko Drives
    Last Post: 04-06-2009, 02:53 PM
  5. Gecko 202 stopped working
    By jimglass in forum Gecko Drives
    Last Post: 04-17-2006, 07:01 PM
