Hello All,
I'm gathering parts for a small router build. I have had this spindle and vfd kicking around for a while. I bought them as a set off of ebay. I did get a booklet with the vfd but no specs on the spindle. I have never successfully configured the vfd to work. Any help would be greatly appreciated. You can see my current router on Instagram @pushmorelongboardsllc I don't really want to use my 5x10 to make skateboards any more. I have the majority of parts to make a dedicated deck router. I'd love to save a few $ and get this spindle to work.
I'm running 220 to the vfd from the same source I run my other vfd. I have changed several parameters, at best when you hit run it starts to spool up for a second or two then quits. "LU" or low voltage fault shows in the screen.
https://youtube.com/shorts/KNRxA8-Z4yQ?feature=share
Attachment 468062
aluminum housing on spindle is approximately 3.5"x5.75" and weighs about 15 or 16 pounds.
Thanks!
Vince
I believe the spindle to be 3kw
vfd is set as follows:
pd00-0
pd01-0
pd02-0
pd03-400
pd04-400
pd05-400
pd007-20
pd08-220
pd09-15
pd10=8
pd11-120
pd13-0
pd-14-12
pd15-12
pd141-220
pd142-10
pd143-2
pd144-2250
pd70-0
pd72-400
pd73-120
