585,888 active members*
5,086 visitors online*
IndustryArena Forum > SignMaking > Signmaking Topics > Inlay With fusion 360
    Jul 2021
    15
    Hello,
    Is there someone has a tutorial to do inlay with fusion 360 in detail... ?
    What i want to do is basically what you can see on the youtube channel "Broinwood"
    its cutting board with precise inlay.
    i will need to use a 18 or 20 degre Vbit, 60 is too big and i dont have 45 degre.
    or if no tutorial i need to know which passes i should use for each part, inlay and pocket. and some detail about setting for each passes.
    I already know that the inlay have to be longer than the pocket.
    Mostly i need to know how to tell fusion 360 to carve that angle nicely on both side.
    thanks in advance!
    Nov 2014
    724
    Re: Inlay With fusion 360
    I've asked the same question, even sent Lars Christensen the link to Broinwood's channel but I don't think he's made a video yet. I bought Carveco and have done these inlays with that software but I would still like to do them with Fusion 360.
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Jul 2021
    15
    So its way more complicated to do with fusion 360 than carveco or Vcarve ?
    Which software you would advice to a beginner then ? (im beginner but i learn fast and i feel this activitie will be my passion )
  1. help Fusion 360
    By thiagocnc in forum Autodesk CAM
    Last Post: 01-06-2021, 09:00 PM
  2. Fusion 360
    By kenrc in forum Autodesk
    Last Post: 10-16-2018, 04:14 AM
  3. Fusion 360
    By Steve Seebold in forum Tormach Personal CNC Mill
    Last Post: 11-23-2016, 09:13 PM
  4. Fusion 360
    By Profm in forum Tormach Personal CNC Mill
    Last Post: 03-03-2016, 11:26 PM
  5. Fusion 360
    By etg711 in forum Autodesk
    Last Post: 11-24-2014, 11:29 PM
