586,011 active members*
4,388 visitors online*
IndustryArena Forum > Additive Manufacturing / 3D Printers and 3D Scanners > 3D Printer / 3D Scanner Discussion > What is needed for a 4 axis printer and what's is the estimated cost?
    Question What is needed for a 4 axis printer and what's is the estimated cost?
    I am a new student and want to get into CNC machining. I built my 3d printer. I have fixed a resin printer before, and I want to take the next step; I like precise parts, which seems like a cool project. Here are some of the things I have found so far.
    https://www.amazon.com/Longruner-Ard...a-803031210947
    this is a thread where it would be cool to lost all the parts that are needed
    also, I want to build this one with a coolant.
    Apr 2004
    5737
    Re: What is needed for a 4 axis printer and what's is the estimated cost?
    What are you going to use the 4th axis for?
    Andrew Werby
    Website
  1. Replies: 5
    Last Post: 02-27-2020, 02:24 PM
  2. Low cost swiss/screw machine shop needed
    By stizzit in forum RFQ (Request for Quote)
    Last Post: 09-14-2018, 01:09 PM
  3. Cost efficient HD 3D printer for direct casting
    By Storen in forum 3D Printer / 3D Scanner Discussion
    Last Post: 12-08-2016, 10:36 PM
  4. Pros and Cons of 3D printer designs needed
    By Mr.Chips in forum 3D Printer / 3D Scanner Discussion
    Last Post: 07-12-2015, 11:14 PM
  5. estimated run time
    By juxtoposed in forum Mastercam
    Last Post: 05-20-2008, 02:50 PM
