585,925 active members*
3,399 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > First 3D Carving Project on Hardwood
    Jun 2009
    Question First 3D Carving Project on Hardwood
    This project turned out pretty good except for the artifacts seen in the photos. I used a 1/16" tapered bull nose. Did I set up the machine wrong or is this normal for hardwood (oak I think)?
    1222
    Re: First 3D Carving Project on Hardwood
    I don't think you did anything wrong,any woodworker will tell you that some pieces of wood are more difficult to work than others of the same species.Its certainly not unusual to have to clean up a few fuzzy edges and a small,sharp chisel will almost certainly make short work of it.Its pretty clear that when you were cutting the fibres that didn't run into the relief sections that the corners were cleaner.
    Jun 2021
    105
    Just jumping in here. I am wondering if these are for personal use or sale - no need to answer that. I am a member of other forums, and many members who have created items such as this have had Harley Davidson (lawyers) contact them warning them to stop. Apparently they (HD) are very active in protecting their copyrights.
    Feb 2020
    6
    [QUOTE=jsthomps;2465566]This project turned out pretty good except for the artifacts seen in the photos. I used a 1/16" tapered bull nose. Did I set up the machine wrong or is this normal for hardwood (oak I think)?[/QUOTE
    I do woodworking as a hobby and working with oak you tend to get fuzzys as I call them. But from what I understand with cnc if you go a little slower on the feed you will have less fuzzys. But that is using a palm router doing inlays by hand. I am just now starting out adding a cnc to my tools to do inlays and such since my hands shake a little since my stroke.
  1. K40 and hardwood
    By RECreations in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-19-2016, 02:59 PM
  2. Best hardwood for CNC 3d carving ?
    By jmf in forum Uncategorised WoodWorking Machines
    Last Post: 05-04-2014, 03:00 AM
  3. Crosscutting Hardwood
    By boydage in forum DIY CNC Router Table Machines
    Last Post: 10-16-2013, 04:26 AM
  4. hardwood part
    By Greg Maxwell in forum RFQ (Request for Quote)
    Last Post: 11-13-2011, 05:02 PM
  5. Relief carving small detailed parts - V-carving from greyscale image
    By ALAN2525 in forum Uncategorised CAM Discussion
    Last Post: 02-12-2007, 12:01 AM
