585,977 active members*
4,487 visitors online*
Results 1 to 6 of 6
    Aug 2021
    Brazing Cast Iron Weather vane
    I'm trying to repair this directional(East-West) cast iron part. I'm using brass fluxed rods. I'm getting soot buildup on the piece and no attachment. Setting Acetylene to 5 psi and Oxygen to 30 psi. First attempt I got it connected. No soot. Part was not lined up properly, and ran out of oxygen, so parts were disconnected and lined up and clamped. Settings were the same, but soot all over cast iron. Pieces were pre heated in oven to 475 f. Torch was applied to cast iron to get it red. Fluxed rod applied to cast iron and heated with torch.
    Any guidance will be appreciated.
    Ron
    Dec 2013
    5717
    Re: Brazing Cast Iron Weather vane
    Sounds like you didn't adjust the flame correctly. But when brazing, the flame should be slightly carburizing. Blue with just a slight ''tail'' on the flame. Normally I would set 5 and 5 on the regulators depending on what size tip you are using.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2021
    Thanks for the information. I'll try that today.
    Ron
    Aug 2021
    Thanks to Jim, my brother's weather vane is repaired.
    Thanks, Jim.
    Dec 2013
    5717
    Quote Originally Posted by Ron6519 View Post
    Thanks, Jim.
    My pleasure to help out. Happy to hear you got it fixed.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2022
    Well explained.
  1. tracing out 4 weather vane printed diagrams
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 05-01-2020, 09:19 PM
  2. weather vane draw digitize and plasam cut
    Last Post: 05-12-2017, 04:52 PM
  3. Cast Iron
    By Zumba in forum Casting Metals
    Last Post: 01-22-2009, 10:50 PM
  4. Defect In Cast Iron?
    By Oldmanandhistoy in forum Uncategorised MetalWorking Machines
    Last Post: 09-02-2007, 02:05 AM
  5. Machining cast iron
    By itsme in forum MetalWork Discussion
    Last Post: 07-19-2005, 03:45 PM
