Originally Posted by
mactec54
The 3 switch circuits S1 S2 S3 have to be connected to Com for those inputs to work, so the Neg side of the switch has to be connected to Com on the VFD Drive not the PE Ground
Each switch will have to be programed in the drive for the speed you want it to run at, I will check and see what you can do for that part, mean time be careful what Parameters you change as you can create more problems if you set the wrong Parameters
So, what speed do you want the low speed and high speed to be???
