586,000 active members*
4,870 visitors online*
    Aug 2021
    Question CNC Tapping problems!
    Hello folks,
    Need Help!
    I have issues with tapping depth. it's always vary anything between .50mm to 2.0mm.. (I know it's weird..).
    Rest of the operations (drilling,milling.etc.) are fine!!!!
    Machine Type: Galaxy CNC Milling
    Controller : Centroid
    OS : Windows
    please see the attached photos!!!
    Any help would highly be appreciated!!!
    TIA.
    Nov 2007
    361
    Sounds like a centroid acorn question go to their forum im sure someone there will help . You can try adding a number value after the z-5. Try something like z-5.001 this way the motor will have to dial in closer to the given number this helps with industrial cnc machines im not sure about centroid
    Aug 2009
    1573
    Re: CNC Tapping problems!
    old thread so, this is a moot point how it was fixed back then without a report back.
    ...try using G61 for exact stop before G84...G64 to cancel
    https://www.centroidcnc.com/centroid...nd_M_codes.pdf
  1. Tapping problems
    By kurikka in forum Community Club House
    Last Post: 10-30-2013, 05:19 PM
  2. tapping problems
    By juniormachinist in forum Mastercam
    Last Post: 10-15-2013, 03:13 AM
  3. Tapping problems MV-40
    By bbarber80 in forum Mori Seiki Mills
    Last Post: 03-27-2012, 04:09 PM
  4. tapping problems.
    By fmcbrandon in forum Okuma
    Last Post: 05-29-2011, 02:49 PM
  5. TAPPING PROBLEMS
    By littlerob in forum Uncategorised MetalWorking Machines
    Last Post: 05-20-2009, 05:37 PM
