585,917 active members*
3,487 visitors online*
    Oct 2020
    Laser cutting in 12mm bamboo gets burned
    I have a 130w laser, but I cant seem to cut 12 mm bamboo plates without it getting burned. Is it simply impossible to cut through bamboo this thick with a laser, or my settings completly wrong?
    Setting: 5mm/s power: 73% (max power to keep laser life) single pass…
    I have a 3” lens and Reci W6 tube
    Dec 2006
    124
    Re: Laser cutting in 12mm bamboo gets burned
    If you use a small orifice nozzle with high pressure compressed air (30 psi), then you will get much better results--less burn-back, higher cut speed, reduced side-wall charring.
    Attached Thumbnails Attached Thumbnails four_inch_lens_nozzle_cutting_thick_solid_wood_300x300.jpg
  1. 3015 1000watt Fiber laser type cutting machine for 3-12mm metal
    By DamonQ in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-08-2016, 03:18 AM
  2. Replies: 0
    Last Post: 08-07-2014, 02:46 AM
  3. Laser cutting leather - How to reduce burned edge
    By dalianharley in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-22-2013, 03:52 AM
  4. Laser Cutting 3/8" White Acrylic & Getting Burned Edges
    By RJlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-06-2010, 04:52 PM
