586,009 active members*
4,884 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Circular pattern limiting instances
    Aug 2016
    32
    Hi
    I'm trying to produce a spiral bevel gear and whilst I've cut the tooth profile i can only circular pattern 27 teeth out of the 40 I require.
    What prevents this and how do i overcome it?
    The file is attached.
    Bob
    Aug 2011
    252
    Re: Circular pattern limiting instances
    I just download your file, opened your circular pattern and typed in 40, I do not see any problem.
    Mar 2008
    683
    Quote Originally Posted by adidoro View Post
    DITTO. No problems using SW 2017
  1. Circular pattern
    By hassanmirabi in forum Solidworks
    Last Post: 05-17-2015, 08:44 PM
  2. Circular bolt pattern wizard question
    By SwampDonkey in forum Mach Wizards, Macros, & Addons
    Last Post: 09-01-2013, 06:14 PM
  3. circular pattern
    By timothy svec in forum Rhino 3D
    Last Post: 05-09-2010, 04:23 AM
  4. Is there a Circular Hole Pattern function in Dolphin?
    By millnturn in forum Dolphin CAD/CAM
    Last Post: 01-21-2010, 04:21 AM
