585,748 active members*
3,453 visitors online*
Results 1 to 5 of 5
    PS191 alarm fanuc 6M
    so I have had this before in the past and never really been able to figure out the problem ,,, randomly when running a g03 it throws this PS191 alarm ,.,
    Accumax with 6M fanuc Attachment 468480Attachment 468482
    www.wildhorsemfg.com machinist / gunsmith
    accumax with Fanuc 11M , Hitachi seiki 3NE with 6T
    Re: PS191 alarm fanuc 6M
    not sure why I said 6M ,, its a 11M
    An arc, where the difference of radius values at start point and end point is larger than the parameter set value, was specified. (parameter No. 2410) Fanuc book says modify the program.
    well yes , I did read what the code meant .. I just dont see how it could be causing a problem . The 11M manual shows that is a acceptable code
    guess like usual .. I have issues no-one else has heard of .. anyways I have switched from bobcad to Fusion360 and if I post as force Radius arcs everything works fine .....
  1. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  2. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  3. PS191 Error????
    By Jokeapri in forum Fanuc
    Last Post: 02-09-2010, 01:39 AM
  4. PS191 error, need help FAST!!!
    By SpYnOnU in forum Fanuc
    Last Post: 11-20-2007, 09:51 AM
  5. Okamoto Grinder W/Fanuc 11M PS191 Error -- Help!
    By John Salisbury in forum Fanuc
    Last Post: 03-01-2007, 03:44 PM
