584,866 active members*
5,319 visitors online*
IndustryArena Forum > Other Machines > Commercial Products / Manufacturers Support Forums > Automation Technology Products > DDCS Motion Control System with MPG, Testing with NEMA 34 Stepper Motor
Results 1 to 1 of 1
    https://www.youtube.com/watch?v=FXDUhf2oogE
    https://www.youtube.com/watch?v=8gqWXBfoJKM
    Product Link:
    https://www.automationtechnologiesin...system-nema-34
    This system is assembled and tested. Its ready to run.
    We can also build 2 to 4 axis. Contact us if you need.
    E-mail: [email protected] Phone: 847-984-0882
    Product Included:
    • 1pc DDCS Motion Controller with MPG
    • 3pcs KL34H2120-60-4A Stepper Motor
    • 3pcs KL-8070D Digital Stepper Motor Driver
    • 1pc 72V/8A Switching Power Supply
    • 1pc 24V/2A Switching Power Supply
    • 3pcs Inductive Proximity Switch, NPN
    The DDCS numerical control system adopts the ARM+FPGA design framework. The ARM can finish the part of human-computer interface and code analysis and the FPGA can finish the part of underlying algorithm and control pulse generate, with the reasonable design, reliable control and easy operation.
    The panel layout structure of DDCS is rational. The common off-line operation can be finished only by 17 keys and it supports the FANUC with high universality to be compatible with G code set. This specification introduces the operation method of caving machine’s special off-line CNC system, DDCS and the machine tool connection as well as operation specification. By lots of graphical representation and examples, the uses can quickly learn to use the DDCS CNC system.
    DDCS has made the following changes on the basis of DDCS:
    1:The input signal is modified to support the NPN switch;
    2: Support limit and the home share the input port;
    3: Use the more stable FLASH, to ensure that no program loss;
    4: Upgrade algorithm, support soft interpolation, modified V1.1 version of arc
    interpolation bug;
    5: Upgrade the power module, the system is more stable
    4-Axis MPG
    The CNC 4 Axis handheld controller MPG Pendant handwheel with x1, x10, x100 selectable, You are bidding one complete unit of the MPG pendant with Emergency stop for 4 axis CNC machine, it equipped with our popular machined MPG unit with 4 axis and scale selector, LED indicator also send feedback from the CNC machine to user about the status of the unit.
    - All Wiring isolated from MPG unit and provide a easy to install wiring diagram, it suit both commercial machine as a replacement jog control unit or other computer based controller. Which add great control flexibility to the system.
    Features :
    - x1, x10, x100 switch
    - X,Y,Z,4th axis selector switch
    - LED indicator
    - With Emergency stop
    - High quality professional chassis
    - 6ft extendable high quality shielded cable cord
    - Magnetic base holder can place anywhere on the machine steel surface
    - Required 5V+, 150mA, power for MPG
    - Phase output is A ,/A and B,/B;
    - TTL output, drive capability +-20mA;
    Support CNC System:
    Taiwan Pou Yuen M600 M500 M520i T300 series, Higerman, HANUC,GSK,opened NC, KND,S, the NUM, Spain FAGOR (NEW, 8055I) and so on.
  1. Testing NEMA34 Closed Loop Stepper Motor System-Hybrid Servo Kit 1128 oz-in with 60VD
    By automationtechinc in forum Automation Technology Products
    Last Post: 08-12-2021, 07:02 PM
  2. 3 Axis EtherCAT NEMA 23 CNC Motion Control System with Mach4
    Last Post: 06-22-2021, 03:09 PM
  3. Testing CNC Motion Controller (500KHz) DDCS V3 CNC Control
    Last Post: 06-13-2021, 08:10 PM
  4. NEMA 23 Closed Loop Stepper Motor System-Hybrid Servo Kit
    Last Post: 07-22-2018, 05:53 PM
  5. Replies: 0
    Last Post: 12-17-2013, 01:14 AM
