585,954 active members*
4,650 visitors online*
Threaded View
    Mar 2019
    5
    Mach 3 setup - errors
    Hi People.
    I'm no programmer etc. I set the machine years ago and running Mach3 USB on a Chinese router. 3 Files have run happily for a LONG time. That means you forget what you did when you set it up originally, so when something goes wrong, ou are out at sea!
    Machine then started to lose Y axis. Checked stepper motor and swapped with Z motor. Didn't fix it. etc.
    Then I decided it was the Chinese copy of the Mach 3 that might be buggy so purchased a full separate Mach 3 licence...and that's when the problems really began.
    First it wasn't Mach 3 at all. It turns out that the problem had been worn slide bearing and they were jamming! (Feeling a little dumb...)
    Having replaced the bearings etc, now I do really have software / setup problems.
    The job of the machine is to only cut concentric circles.
    But the new software (and the original)needed setting up from scratch and now it doesn't like the original files. It's throwing up G90/91 errors under "Abnormal Operation"
    When checking the code it is always stopping at line 14 with another error code..and of course it won't run at all.
    And finally the image on screen is no longer concentric circles but screwed circles.
    I've changed IJ from Absolute to incremental. No joy.
    First image shows the correct image to the file (second image) Next is the error message and finally the erroneous image of the eccentric circles.
    Attached Thumbnails Attached Thumbnails Correct image.jpg   File.jpg   error description.jpg   wrong image.jpg
  1. MAPPS graphics errors and setup questions
    By UWP_Wes in forum Mori Seiki Mills
    Last Post: 04-01-2011, 08:05 AM
  2. Mach 3 errors
    By ajclay in forum Mach Software (ArtSoft software)
    Last Post: 12-14-2009, 12:57 PM
  3. Errors on Arc in Mach
    By MichaelHenry in forum Tormach Personal CNC Mill
    Last Post: 10-24-2009, 12:38 AM
  4. Mach 3 Z errors? Crashed my tool!
    By Shamanjim in forum Mach Software (ArtSoft software)
    Last Post: 05-22-2008, 04:55 PM
